Hi All...
At the end of my tether with this now :/ I've ripped the car apart trying to find a fix, but still cant find a solution. It's Audi A3 BKD 2006 8P with DSG
It started with flickering dash clocks, the radio asking for a code sometimes and then next day the instrument cluster was dead and car wouldnt start. It had been sat for a week or two while I changed the turbo, so it had to be jump started twice, and when the battery was low I used to get ESP Fault on the dash, but after a run that went.
After extensive googling, it appeared all roads led to instrument cluster being dead and I sent them off to be repaired at a cost of £160. They replaced the processor and sent them back. However, when I (all happy smiles) put it back in, the dash clocks were still dead - no lights, clock, etc.. so I sent them back to the repair company under warranty. Speaking to the guy on the phone he said "They're lighting up on my bench" but replaced the processor again to be sure, then sent them back. Yet, on my end still dead.
All other electrics work, both keys lock and unlock, indicators work, headlights etc. Before sending the clocks off I did the usual checks:
Checked dash fuses . Engine fuses . Checked battery . Tried another battery . Had the battery tested by tyre centre and was told it was good, no dead cells.
Swapped some relays on comfort control module (under drivers dash) . Bought a relay tester and cycled through relays - all good (But I couldnt test the larger relays as the pins wouldnt fit in my tester)
Swapped comfort control module with one from a breaker
Swapped CAN gateway module from a breaker
Checked CCM in boot for water/damage
Checked ECU for water damage
I bought a 2nd hand instrument cluster off eBay (same part No.) That didnt light up either. Bought yet another instrument cluster, that is the same. The seller sent me a pic of it off the car and it was shown working at his end.
I've put multimeter on the fuses and getting 12v.
Lastly, the loom to the instrument cluster, I've put the multimeter to what I think is positive pin 1, and I get around 9v? It's the singular 'blue' 32 pin connector.
I can't think what else to do.. ignition switch? or maybe the cluster isnt coming on with only 9v supply? This is the scan with OBDeleven.
Date: 2020-02-13 18:13
VIN: WAUZZZ8P87A050925
Car: Audi A3
Year: 2007
Body type: Sportback
Engine: BKD 103 kW (140 HP) 2.0 l
01 Engine Control Module 1
System description: R4 2,0L EDC 000AG
Software number: 03G906021LG
Software version: 9558
Hardware number: 03G906021AN
Serial number: AUX7Z0F7FN70DV
Coding: 0000078
Trouble codes:
P1650 - Databus drivetrain missing message from instrument cluster
static
Priority: 3
Frequency counter: 2
Driving cycle: 255
U1019 - Instrument cluster control module Missing signal oil level/temperature
static
Priority: 3
Driving cycle: 255
P161C - Glow plug cylinder 3 Open circuit
static
Priority: 3
Frequency counter: 1
Driving cycle: 255
02 Transmission Control Module
System description: GSG DSG 070
Software number: 02E300042S
Software version: 1102
Hardware number: 02E927770AE
Hardware version: C30
Serial number: 00000606270164
Coding: 0000020
Trouble codes:
P1862 - Databus drivetrain missing message from instrument cluster
static
Priority: 0
Frequency counter: 255
Driving cycle: 40
03 Brakes 1
System description: ESP FRONT MK60
Software number: 1K0907379AC
Software version: 0101
Hardware number: 1K0907379AC
Coding: 0023170
Trouble codes:
01317 - Instrument cluster control module No signal/communication
static
00474 - Anti-theft immobilizer system control module No signal/communication
static
08 Air Conditioning
System description: KlimavollautomatH18
Software number: 8P0820043Q
Software version: 0300
Hardware number: 8P0820043Q
Hardware version: 000
Serial number: 8P0820043Q
Trouble codes:
00483 - Auxiliary air heater control module Please read DTC
static
Priority: 3
Driving cycle: 243
static
Priority: 3
Frequency counter: 4
Driving cycle: 243
09 Central Electrics
System description: Bordnetz-SG H43
Software number: 8P0907279F
Software version: 1201
Hardware number: 8P0907279F
Hardware version: 063
Serial number: 00000006041842
Long coding: F18A5F01B214100000160000160000000008EE175A0500
Subsystems:
System description: Wischer AU350 H01
Software number: 8P2955119E
Software version: 0130
Coding: 0062736
System description: REGENLICHTSENSORH13
Software number: 4E0910557A
Software version: 0090
Coding: 0150573
Trouble codes:
01341 - Control module in instrument cluster at comfort CAN No signal/communication
static
Priority: 2
Driving cycle: 243
11 Engine Control Module 2
Trouble codes:
No trouble codes found
15 Airbag
System description: Airbag 9.41 H12
Software number: 8P0959655C
Software version: 3760
Hardware number: 8P0959655C
Serial number: 003620G1JHAV
Coding: 0071612
Trouble codes:
static
Priority: 2
Driving cycle: 243
16 Steering Column Electronics
System description: J0527 H34
Software number: 8P0953549F
Software version: 0070
Hardware number: 8P0953549F
Coding: 0014112
Subsystems:
System description: E0221 H07
Software number: XXXXXXXXXXX
Trouble codes:
static
19 Gateway
System description: J533__Gateway H12
Software number: 1K0907530J
Software version: 0160
Hardware number: 1K0907951
Serial number: 32001067188088
Long coding: 7F3F0BC887003103
Trouble codes:
00381 - Instrument cluster data bus No signal/communication
static
Priority: 1
Driving cycle: 243
01342 - Engine control module 2 No signal/communication
static
Priority: 2
Driving cycle: 243
01044 - Control module incorrectly coded
static
Priority: 1
Driving cycle: 243
25 Immobilizer
Trouble codes:
37 Navigation
System description: RNS-E HIGH EU H72
Software number: 8P0035192H
Software version: 0500
Hardware number: 8P0035192H
Hardware version: 014
Serial number: AUZBZ7F0970832
Coding: 0209717
Trouble codes:
16352 - Control module Faulty
Intermittent
Priority: 5
Driving cycle: 65
Mileage: 1432 km
Date: 2006-09-18 00:22:47
static
Priority: 5
Driving cycle: 243
42 Door Electronics Driver Side
System description: Tuer-SG 020
Software number: 8P0959801G
Software version: 0110
Coding: 0000688
Trouble codes:
44 Steering Assistance
System description: EPS_ZFLS Kl.079 H07
Software number: 1K2909144L
Software version: 1806
Trouble codes:
00778 - Steering angle sensor
static
46 Central Module Comfort System
System description: KSG H04
Software number: 8P0959433C
Software version: 0050
Long coding: 198000186D088505489FC63300
Subsystems:
System description: LIN BACKUP HORN H03
Software number: 1K0951605C
Software version: 1301
System description: Neigungssensor 005
Software number: 1K0907719C
Software version: 0003
System description: Innenraumueberw.H04
Software number: 8P0951177
Software version: 0020
Trouble codes:
52 Door Electronics Passenger Side
Software number: 8P0959802G
Coding: 0000688
Trouble codes:
55 Headlight Regulation
System description: Dynamische LWR H02
Software number: 8P0907357F
Software version: 0010
Coding: 0000012
Trouble codes:
static
Priority: 2
Driving cycle: 243
Mileage: 8 km
56 Radio
Coding: 0209717
Trouble codes:
Intermittent
Priority: 5
Driving cycle: 65
Mileage: 1432 km
static
Priority: 5
Driving cycle: 243
62 Door Electronics Rear Left
Software number: 8P4959801D
Coding: 0000144
Trouble codes:
72 Door Electronics Rear Right
Software number: 8P4959802D
Coding: 0000144
Trouble codes:
76 Parking Assistance
System description: Parkhilfe 4-Kan H09
Software number: 8P0919283D
Software version: 0060
Hardware number: 8P0919283D
Serial number: 00067824820621
Coding: 0001113
Trouble codes:
77 Telephone
System description: FSE_255x BT H21
Software number: 8P0862335H
Software version: 0290
Hardware number: 8P0862335H
Serial number: 00000000513248
Coding: 0011422
Trouble codes:
static
Priority: 5
Driving cycle: 243
7D Auxiliary Heater
System description: PTC-Element
Software number: 1K0963235E
Software version: 0404
Hardware number: 1K0963235E
Trouble codes:
00361 - Heater element for aux. heater Faulty
static
Car: Audi A3
Year: 2007
Coding: 0000078
Trouble codes:
static
Priority: 3
Driving cycle: 255
static
Priority: 3
Driving cycle: 255
static
Priority: 3
Driving cycle: 255
Coding: 0000020
Trouble codes:
static
Priority: 0
Driving cycle: 40
03 Brakes 1
Coding: 0023170
Trouble codes:
static
static
08 Air Conditioning
Trouble codes:
static
Priority: 3
Driving cycle: 243
static
Priority: 3
Driving cycle: 243
Subsystems:
Coding: 0062736
Coding: 0150573
Trouble codes:
static
Priority: 2
Driving cycle: 243
Trouble codes:
15 Airbag
Coding: 0071612
Trouble codes:
static
Priority: 2
Driving cycle: 243
Coding: 0014112
Subsystems:
Trouble codes:
static
19 Gateway
Trouble codes:
static
Priority: 1
Driving cycle: 243
static
Priority: 2
Driving cycle: 243
static
Priority: 1
Driving cycle: 243
25 Immobilizer
Trouble codes:
37 Navigation
Coding: 0209717
Trouble codes:
Intermittent
Priority: 5
Driving cycle: 65
Mileage: 1432 km
static
Priority: 5
Driving cycle: 243
Coding: 0000688
Trouble codes:
Trouble codes:
static
Subsystems:
Trouble codes:
Coding: 0000688
Trouble codes:
Coding: 0000012
Trouble codes:
static
Priority: 2
Driving cycle: 243
Mileage: 8 km
56 Radio
Coding: 0209717
Trouble codes:
Intermittent
Priority: 5
Driving cycle: 65
Mileage: 1432 km
static
Priority: 5
Driving cycle: 243
Coding: 0000144
Trouble codes:
Coding: 0000144
Trouble codes:
Coding: 0001113
Trouble codes:
77 Telephone
Coding: 0011422
Trouble codes:
static
Priority: 5
Driving cycle: 243
7D Auxiliary Heater
Trouble codes:
static
