Rear damper bump stops.
Charlie Farley
Chilling out.
Staff member
Moderator
At Home
Just a shot in the dark chaps.
Does anyone have a link to b7 s-line damper bump stops.
I need a pair but they are being a bit difficult to locate in uk stocks.
p/n
8E0 512 131 P
This part number is for the sport suspension stop which I require, any help would be excellent.
these are my original oem ones, long past it now....lol
Brake4
There's a fair few listed on the dreaded fleabay but not the correct part when you read the listing carefully and they are not for sport suspension.
Car parts for less have them but I wont use them after the last messup they made, so open to suggestions really.
I think I went for KYB part number 910227 when I did mine last year.
If you've not already got the 'buycarparts' app, it's great for pumping in the OE part number to find loads of different brands :)
Reactions: Charlie Farley
p/n
8E0 512 131 P
I got mine done last month, garage got them from eurocarparts if that's any help
Sent from my SGP621 using Tapatalk
no idea to be honest with how life is at the moment, i wouldnt expect a quick delivery from anyone to be fair
Hi Scott, do you know what the length of the these kyb stops are.
There seems to be several length stops for the sports suspension 110mm and 100mm
I have Bilstein B8 dampers which are shorter than the s-line , I was thinking maybe better to go with the 100mm but the kyb don't state length.
I agree , just a bit cautious really as on a few previous occasions using these companies delivery was problematic and I had been stearing clear of them to a degree in favour or more uk based suppliers.
Reactions: Sygh2k
ECP don't list any of the stops, nor do carparts4less (ECP) , well not the 100mm sport suspension stops that is.
I don't do any maintenance myself, just go by what my garage says.
That's fine chap, I rang ecp today and they only do the standard bump stop, not the sports suspension bump stop which is a lot shorter.
