My (in)Convenience Climate uncontroller system is playing endless games. I have seen plenty of references to the "secret" codes, but all the posts & videos I've seen refer to accessing them on a "Basic" controller, none for the 'Convenience' version. The significant point being that there is no UpArrow (screen vent) button on this version. I have tried every combination of button presses I can think of, can anyone tell me the correct access method?
The problem is various:
I can't stop a roaring cold draught on my feet :-(
The heater randomly graduall comes on to seriously hot (except my feet) and can't be turned down (yes I can twiddle the knobs and the display changes, but the sauna does not)
The heating is usually almost non-existent
The fan (blower) sometimes works, sometimes not, sometimes full blast for a few seconds
I have replaced the blower controller (twice), first time (6 months ago) it appeared to fix the fault, maybe this is the same fault again, or maybe yet another one, but another new controller has not corrected the problem.
I have replaced the inconvenience module (4F2820043H) on the dash with a (used) superficially identical one with the same part no. and same software level and then programmed via VAG-Com to the same set of codes (decimal toggles of a 6-bit byte, sweet jeezus!!) all to no good result. It's either a dud or there is some other problem as it only says 'Off' and refuses to work whatever I press except that the RapidDemist (only) does work.
I have cycled the flaps (via VAG-Com setup) and for those few brief seconds do get a pleasant waft of warm air on my toes so it's not a flap motor problem.
This has unquestionably been the worst car I have ever owned since a Ford 100E 40 years ago - but I only paid a fiver for that so fair enough. This it is a truly atrocious catalogue of failures, faults and endless screaming aggravation, such a disappointment after the earlier 1.9.
Any assistance before I'm dragged off to an asylum would be gratefully appreciated
