These are excellent for conducting these types of repair and you just need a lighter (don’t use a heat gun as the other wires a very close by).
Cut the wire inside the door card and the vehicle and run a new bit of wire.
heatshrink with water tight adhesive on both sides which also acts as a bit of strain relief but also solders the wire together (first obviously twist the pair together then slide this over it)
