Cruise control retrofit problem
Kevin mathews
Age
26
Dubai
Hey guys
Ive got a audi a3 2.0 fsi '07
So i installed the new cruise control alongside changed the steering module as well to 1K0-953-549-F
Coded everythiing and it went well
But when i tried to activate the cruise control it didnt work
Any idea what i did wrong
Any help wuld be appreciated
Sent from my SM-N970F using Tapatalk
1k0 or 8p0 as latter is the correct one.
Assume you coded engine 01 aswell as 16.
Reactions: Eren S3
Hey Kevin,
Have a little read of this retrofit guide (if you haven't already) and see if that helps. It's what I used to retrofit and code mine. Luckily I didn't need to change the module so it was a bit simpler but looking at that guide it seems you should have the correct steering module.
https://lightnings.dk/fartpilot_en.html
Hope this helps!
Keep us posted.
So i didnt change the coding for the engine before and i did it now but still no luck nothing is showing up on the dashboard
The part number should be 8p0 not 1k0
Decode, recode with engine of but ignition on.
Finally got around the problem and the recoding worked. Works like a charm . Now on to the steering sensor recalibration
Much appreciated guys !!
Calibrate angle before testing as cc won't operate.
Hi
I have completed this retrofit today but I'm not sure what you mean by steeringsensor recalibration? And how I would do this?
Hi
If yours doesnt require its not needed.
Is any fault showing on the dash?
No faults showing on dashboard. Well the fault light came on for a few seconds but then went off and never came back on after that
That's normal when fitting cruise & not changing the module & slip ring.
That’s fine. I have a 2008 Audi A3 8p PREfacelift model and I only changed the indicator and cruise control stalk and it worked. I didn’t need to changed the slip ring and module.
