Audi 8v halogen to led tail lights upgrade
Tilaat
Leeds
Hi
I have an Audi A3 8v Hatchback.. I want to upgrade tail lights halogen to LED... I have bought the lights but realised the plug are different .. on the halogen the outer light has the brake light bulb ..and the led has brake bulb on the outer and the iner ... is there anyone that can help me with the wiring or point me in the right direction for the harness adapters.. any help appreciated thanks in advance
On the outside taillight the brake and driving lights use the same wire.
On the inside the fog lights and driving lights use the same wire.
You have to remove the driving lights from the outside lights adaptation.
You have to remove the fog lights from the inside light adaptation
Next you need to run 2 wires from inside to outside.
1 Turnsignal (as the inside lights have no turnsignal on halogen)
2 Drivinglight from inside to outside
Now you have 2 reverse wires and 0 foglight wires from BCM
Wiring: remove 1 wire and connect left and right reverse light together.
The loose *ex reverse) wire we hook up to the foglights. (both)
Code 1 of the 2 reverse light as fog lights. ( ths may couse the cluster to get the reverse light error when foglights are out.)
Last : As the led might trigger a lamp out, you can try to change the lasttype.
Do you have wire diagram .. how many wires in total do I need to run from the outer lamp to iner plus can I tap the wire from the wire itself or do I need to connect directly to the pin
As you can see you have 3 wires on the outside lights and 4 on the inside.
This is why all this trouble.
You missing 1 wire on outside and 2 on inside,
Wiring: you need 2 wires , turn signal and driving lights from inside to outside.
Same on other side.
Next you need to combine reverse lights to work on 1 wire from bcm
Next you need to combine fog lights to work on 1 wire from bcm, We are using old reversing wire and code this to Fog.
I do this because i want t have 2 wires for driving lights (moving part)
Almost forgot.: As the drivinglighs are now led and the old halogen needed dimming you need to adress the dimming of the drivinglights too!
I did this this to my A3 with second hand led tail lights and a wiring loom from K-electronics. I installed the wiring loom and tail lights and coded it with a handy tool called OBDeleven.
Same on other side.
Cheers pal I will try this tomorrow see how I get on as for the plug can I buy just the plug from dealer and tap the wires. Also do you have contact number
Can’t order anything from there site as it is in German language
Chrome has build in translator. (laptop or desktop)
Same on other side.
Do you know the coding to change to do the reverse and fog lights? iv retrofitted mine but no fogs, clever idea mate
Is it possible to fit FL LED tails on FL halogen?
i didnt think they did halogen on fl?
anyway the rear clusters from 2012 8v will fit upto a 2019 8v and vice versa with the right pinouts and coding
Yes there is FL with halogen tails.
So there should be a way, it's just matter of wirings and coding.
@m rol
Same on other side.
kun je dit op afstand voor mij programmeren?
I also have a wiring loom from k-electronics, can you help me with coding a have vcds.
Same on other side.
can somebody help me with this.
i don't understand this part
Hello brother I used a harness aswell now the inner brake light is staying on and shines brighter when the brake is pressed (stays on when I turn the light switch on at night) what coding is needed to turn off that running brake light
Hello Guys, i have also an Fl a3 with hallogen, and i want to install Fl led.
I want to do myself the cable.
If i understand well, we need to run 2 cable of the turn signal to the BCM in de front, i find that we need to connect it in pin 3 and 9. ( i still don’t know sides exactly but i will make a test to see with one is the left/right) after that 1 wire need also to go to the front for permanent 12v. I will purchase the 4 correct plug at the dealer, and i will try to do my self the cable. I find nothing on the forum about that. and i didn’t find the cable set less than 150€ (i think it’s very expensive for a cable set…) on aliexpress a lot of cable less than 50€ but only for prefacelift modele, not same connector than facelift (i think only trunk tail connector are different)
If some one can help or share something it’will be grateful !
Thanks ✌️
Thanks ✌️
You managed to do it?
Let me know if you want to make wire harness yourself..
Check this...
Have you managed to fix this?
Have you managed to fix it?
Question: retrofit pfl led in my 2013 hallogen Sportback. my brake lights burn both in normal position. Is this vcds resolveable?
Turn signal and fog light work
Explain... Burn both, Brake light and? What you mean Normal position?
What you see on the photo is me just turning light on. No braking, no reverse no fog lights just normal lighting
Verzonden vanaf mijn iPhone met Tapatalk
Ok.. looking at it suggests you have Brake function added to your TailLight channels.. that is adjustable with VCDS..
Kindly inspect again, your fog lights that it is fully off when it should be and Not dimmed.
Also check if Brake light change Brightness when U press Brake Pedal.
Ok it is just a vcds thing. That is what is did not do . Friday is vcds friday
You need to check your Brake light channel as well.. maybe it comes on because you have it set as Leaving/Coming Home light but it should not be on when you drive.. make sure you don't have Taillight function in Brake light channel...
You can send me admap I will return you with changes.
I got it sorted by a vcds professor!
One by one the lights turned of by every code he made in vcds. So yes it is a coding issue when swapping led for hallogen! Thnx everybody and hope this helps anyone trying to do the same!
Reactions: ZeA38VSport
Beste, ik wil hetzelfde doen. De led achterlichten heb ik aangekocht en moet de kabels adaptors kopen. Ik installeer dan de nieuwe led achterlichten.werken de lichten dan of werken ze pas echt als ze in vcds geprogrammeerd worden? Alvast bedankt
If you got 2013-2016 A3 with Halogen rear lights from factory and changing to 2013-2016 LED set
Then you need harness, one each side, that links inner and outer lights
Coding will make LED look like factory fit
Without coding you will have no issue but fog and brake will stay On dimmed at Night all the time.
Reactions: NivenA3
Hi there your info is very useful.
I currently have an audi a3 sedan/ saloon model. I have the led tail lights and the harnesses to connect the outer and inner lights. My problem is as follows. On the left side i have the dynamic turn signals
On the roght side the inner tail light has the dynamic tail light however the outer tail light on the right side flashes with a red light. No oiter dynamic tail light. The inner tail lights switch on but the oiter tail lights do not switch on when the rear fog is switched on. The reverse lights do not come on when reverse gear is engaged. Is there anyone who can help me with the coding for this pls.
Any help at all will be highly appreciated. Im in south Africa and not alot of people have the knowledge or willingness to share the info without charging stealership prices.
Hi
Do you have vcds or obd tool Please share your current coding for taillights
I had some problems with the tail light of my Audi. I noticed that it isn't working after one month after it stopped working. I have bought some new tail lights from https://www.vont.com/product/smart-strip-lights-led-strip-lights/, and I even figured out how to install them on my own. It wasn't so hard, so I decided to upgrade all light bulbs on my car to LED light bulbs. It was a good decision because my car looks much better, and most importantly, the visibility during night driving is way better.
ive managed to get the rear FL Halogens on my Sport saloon upgraded to the FL Led. i worked with rocketwires to make a kit up. might be worth messaging them about it, im not sure if theyve started selling the kits yet.
Inside:
Here you are missing the turn signal wire....
So we need to get those from the outside lights.
Halogen coding:
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,16;
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,16;
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,16;
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16;
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0 ,16;
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0 ,16;
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0 ,16;
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,16;
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08 ,16;
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16;
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,16;
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,16;
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,16;
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16;
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,16;
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,16;
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,16;
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,16;
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,16;
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,16;
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,16;
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,16;
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16;
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0 ,16;
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0 ,16;
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0 ,16;
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18 ,16;
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18 ,16;
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16;
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,16;
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,16;
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,16;
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16;
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,16;
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,16;
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,16;
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,16;
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,16;
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,16;
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,16;
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,16;
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16;
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0 ,16;
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0 ,16;
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0 ,16;
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16;
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16;
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16;
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,16;
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16;
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,16;
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase ,16;
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,16;
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,16;
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,16;
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,16;
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,16;
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,16;
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,16;
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,16;
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16;
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,25 ,16;
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,25 ,16;
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0 ,16;
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16;
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16;
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,13 - Bremsleuchten ,16;
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,16;
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16;
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,16;
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16;
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16;
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv ,16;
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16;
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16;
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16;
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,16;
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,16;
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,16;
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16;
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,25 ,16;
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,25 ,16;
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0 ,16;
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16;
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16;
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,13 - Bremsleuchten ,16;
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,16;
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16;
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,16;
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16;
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16;
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv ,16;
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16;
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16;
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16;
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,16;
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,16;
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,16;
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16;
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0 ,16;
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0 ,16;
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0 ,16;
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,16;
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29 ,16;
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16;
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,16;
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake lamp ,16;
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16;
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active ,16;
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,16;
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,16;
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,16;
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,16;
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,16;
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize ,16;
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,16;
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,16;
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,27 ,16;
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16;
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0 ,16;
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0 ,16;
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29 ,16;
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,16;
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Gl�hlampe 27W: auch H15 ,16;
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,16;
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16;
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16;
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16;
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16;
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16;
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16;
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16;
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16;
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize ,16;
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,16;
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,16;
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,27 ,16;
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16;
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0 ,16;
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0 ,16;
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,16;
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,16;
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Gl�hlampe 27W: auch H15 ,16;
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,16;
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16;
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16;
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16;
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16;
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16;
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16;
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16;
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16;
led
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lights ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lights ,16
Dont forget to put the lightmodes to led...
On oem led equiped cars you have light 16 and 17 controlling the indicators... These are used for something else on non led cars..
I have A3 8V taillight harnesses listed on eBay.
