Problem Coding RNSE Bluetooth
Munteanoo
Tg. Jiu
Hi everyone, just a quick question
I bought one of those AUX port bluetooth adapters, i wired it in and updated the RNS-E to SW0650
When i tried to code the bluetooth adapter in with VCDS 19.6, I could only connect to the engine and ABS modules. Whenever i tried the navigation(37) one, or any other one besides engine and ABS, I would get an error, something about module not responding or not being seen by VCDS.
The RNS-E came with the car, it's not retrofitted.
Assuming you're turning the ignition on, some forget to do this with vcds.
I would bet on non genuine vcds, they don't connect with all controllers
Did your car have a CD player in the glovebox?
Which Bluetooth receiver are you trying to connect?
You should be able to connect to more than 2 modules, you wont unless your using a genuine VCDS cable or OBD11 dongle.
you have not said what cable your using?
Hi
Tried using 19.6 VCDS, not genuine copy, and a licensed VCDS, not sure what version, from a mechanic friend, neither have worked.
Yeah, 6 slot CD Mag in the glovebox
I bought one of those bluetooth adapters that goes in the back of the navi and connects in the 32pin aux port at the back of it
My bet was on a non genuine vcds, they work like that. Considering your garage friend and his vcds being genuine and problem persists. It's your car.
Try coding your satnav in a different car maybe?
Gonna have it taken to an electrician, some other B7 owners from my country told me they had encountered the same problem and it was something to do with the rnse getting its power from the power cables of the OBDII port of the car or something along those lines. Plus, its not only the navi module i cant connect to, nothing but the engine and the ABS modules seem to work
Yeah it looks like a car problem to me, or fake vcds. If you had another stereo before the satnav then the k-line could be misplaced as well. Different units have kline in a different location, but since the other controllers are not responding either...
I believe the KLine is connected to the CD player plug on a factory unit, I have a factory RNSE but no CD changer so my KLine is on the
Quad lock connector on the back of the RNSE.
If you remove the Aux blue tooth adaptor, so you just have the RNSE and CD Changer connected as per factory you should be able to
connect to all modules in the car.
I you unplug the CD Changer you will lose the KLine so you would have to move the KLine wire.
What country are you in?
K-line has nothing to do with cd changer
In romania, but the car is from germany, it was configured and bought there, i bought it 2nd hand
