Hi Yesterday afternoon I ran into a problem, so as I was just driving down my local area I came to set of traffic lights and noticed my car beginning to idle abnormally, not taking to much notice of it I continued driving and I began experiencing jerking and it just cut out in the middle of the road. I managed to get some help and push it on to a side road. I tried to start it and the car would just cut off right away, completely baffled... anyways after a few attempts I managed to get it started and drove it home under 1.5 rpm and noticed as I was building the throttle the car would start cutting out power and start hunting. Now I have done some research of my own and it turns out it can a few different things such as Mass Air Flow Sensor, fuel pressure sensor/regulator, diverter valve, boost pipe leak.
I disconnected the Mass Air Flow and the car starts behaving as it should and when connect it back is when the issue surfaces. Seems to be a common issue as I’ve come to know since reading up on it.
I’ve got PCV delete on mine and have also checked the vacuum hoses and no splits. Might be worth checking diverter valve. Some say can be Mass Air Flow, Fuel pressure sensor, regulator. Intake leak
Have you ever ever experienced something like this. Any help would be much appreciated.
