Wednesday,10,June,2020,15:57:23:16688
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WUAZZZ4G7GN903500 License Plate: P16PGM
Mileage: 96788km-60141mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 22 28 30 34 36 3B 42 44 46 52
53 55 5F 62 65 69 6C 6D 72 85 BA
VIN: WUAZZZ4G7GN903500 Mileage: 96788km-60141miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Cannot be reached 0100
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Not registered 0011
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CWUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 560 C HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0002
Revision: NCH63---
Coding: 122A00326536010B2800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906560C 001003
ROD: EV_ECM40TFS0114G0906560C.rod
VCID: 2809FE22F277084B3BB-807C
No fault code found.
Readiness: 1110 1001
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AN HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H19 1002
Revision: --H19---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 7AADF46A5C5B4ADB1DF-802E
Address 03: ABS Brakes (J104) Labels:. User\4G0-907-379-V2.clb
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Revision: -------- Serial number: --------------
Coding: 62B7DA4146ED5B82BF00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 42DD4C8A740BC21B05F-8016
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 01B9704E000000000000
VCID: 7BA3F16E53E173D3069-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2315000204964005
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Component: KLIMA 4 ZONEN H14 0112
Serial number: 11111500040390
Coding: 68221078050000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 6A8DC42A2CFBFA5BEDF-803E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 EK HW: 4H0 907 063 EK
Component: BCM1 2.0 H20 0367
Revision: 25020001 Serial number: 00001203942901
Coding: 0105801440349FE0690140C7A0001800CF9DE70A2F08020180000894E100170200400034030000
VCID: 75B7E75675C525A370D-8020
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 151002 H38 0080
Serial number: 151011021458
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 60905397
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 09 11 2015 00001520
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA121750000015673004
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 26C809D7000000000001
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1007ARXK
Coding: 30333130313730323737554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3B23316E13E1B3D3469-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB400K551R05H8
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB400I551R0A20J
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB405N3K1604OTI
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB40613JRS0B8FM
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400E555N45P6A
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB401A55588B9TA
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372OK8000OM
Coding: 000035
VCID: 372B2D5E2F4997B3A21-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Component: E221 - MFL H08 0010
Serial number: 17 10 2015 A0045146
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G0 920 982 M HW: 4G0 920 982 M
Component: TBenGb Nv H11 0106
Revision: 08001098 Serial number: 658091115596047
Coding: 23AF110B9B412600010400
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 3635205A28C36EBBB97-8062
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002047405
Coding: C0ED07481C
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS_001_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 1727028303
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 150729000000000007E2
1 Fault Found:
0021 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert (CAN)]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 129
Mileage: 96788 km
Date: 2020.06.10
Time: 15:54:29
Voltage terminal 30: 12.0 V
Voltage terminal 15: 11.9 V
Control Module temperature: 36 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 000311150001011
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
ROD: EV_AllWheelDiffeQSPFR.rod
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 10111500041174
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3D273F760DF5BDE378D-8068
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000085210
Coding: 01010101000000000001000102
VCID: 6491AA12CE5FAC2BD73-8030
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008001
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B153ED7995F73FA1-807A
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000171616988
Coding: 0078130000006001000001010101102030303232203232
VCID: 77ABED5E6FC957B3621-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E01V97K
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372B2D5E2FC997B3A21-8062
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F16015E21620002080002
VCID: 47CB5D9E5FA9E733D21-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000001 Serial number: 0000352526
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D346A1CDB8ADB5DF-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0385895471
Coding: 013B0622A0B93880C330098C200113470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00016041895
Coding: 010000
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
VCID: 46D5509A58A3FE3B297-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001652241
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070F36DD952D63C8D-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FE02202A130200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 34311A523EBF7CAB873-8060
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 4G1 035 020 G HW: 4G1 035 020 D
Component: MU-H-ND-EU 051 0910
Serial number: A735J0FB000742
Coding: 017562010000000013111102000A00002F0008F7F1700100DF
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 1D67DFF6AD35DDE358D-8048
Data medium:
Subsystem 1 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY803BWH
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OK5000YG
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 129
Mileage: 96788 km
Date: 2020.06.10
Time: 15:54:36
Voltage terminal 30: 12.2 V
Status_Software_Version_Management-module_name: MBose6416A_P/VDB
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0511
Coding: 010F14004021620002080002
VCID: 49CF5BA649BD1143C45-801C
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000021886
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2A0D042AEC7B3A5B2DF-807E
1 Fault Found:
12652551 - Tire Pressure Monitoring
C10DC 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 129
Mileage: 96788 km
Date: 2020.06.10
Time: 15:54:28
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H07 0072
Revision: 5G001001 Serial number: 00000135966549
Coding: 0100000000000000
VCID: 71BFD34601AD0983AC5-8024
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Coding: 027501010201000300
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914.rod
VCID: 323D1C4AC4AB729B95F-8066
2 Faults Found:
9591827 - Video Signal Line
B125C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 129
Mileage: 96788 km
Date: 2020.06.10
Time: 15:54:28
passive
9661203 - Cable for Video Signal from Rear View Camera
B136B 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 129
Mileage: 96788 km
Date: 2020.06.10
Time: 15:54:28
passive
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 300500735
Coding: 093205C011
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0511
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: E0140000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C010232E68F246BDF3-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813006017201
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:14, VBatt start/end: 12.1V/12.1V)-----------
