Dpf delete
Daniel Evans
Age
31
Warwickshire
Hi, I’ve got a 2011 Audi A3 8p 2.0 tdi, does anybody know if I remover the dpf it’s gunna cause a load of smoke.
It will increase smoke a bit.
Yes what he said, it will go up a little bit but nothing too drastic or noticable. If done properly by using the stock DPF housing it won't fail MOT. If you cut the DPF out and weld a straight pipe there then yes it will visually fail the MOT as the DPF looks like it has been tampered with.
On some cars the dpf isn't even visable particularly the ones that are cat first and dpf second , and a 5ft engine tray.
The MOT test regarding DPFs has got a lot tighter since 2018, they have made MOT testers aware that ppl are re-welding the cans;
Reduce emissions 6 1024x536
Reactions: Daveyonthemove
Do you know how many DPF deleted cars there are out there? That many that the government decided to scrap and penalise diesels because they realised this DPF idea was a failure. The new popular one now is adblue delete. :whistle2:
528
13
6K
