Hi Folks,
So my steering rack has failed again, this happened approx 3 yrs ago so the refurbed rack has not lasted long.
It appears to be leaking from the drivers side of the steering rack, same place as last time I believe.
So my question is, why has this happened in the first place, and why in the same place as last time- is this a common fail area of the rack?
Points to consider:
Cheers all
Jon
Points to consider:
- Pump was not replaced last time
- Reservoir was potentially topped up too high by the garage and then given a test run- could this have blown the seals as the fluid expanded? I removed some of the fluid so that it was back down to the max level indicated on the dipstick the day after I got it home
- The oil they replaced it with was comma MVCHF designed for audis however not necessarily the one specified by audi- what do other people use?
- The oil in the reservoir appears pretty clean, there was a slight grey tinge to the fluid on the end of the dipstick when I first removed it but everything else was clean green
Cheers all
Jon
