Hello
So i have had an issue with my S3 2011 2.0tfsi for 3 weeks now.
1. It will not idle at 900rpm, instead it idles up and down between 900-1900rmp continuously
2. if you put your foot down or pull away from lights at a sensible speed, the car jumps like its misfiring. If you change down a gear for example if you want to over take, the car will not like it and will jump to the point theres just no point trying to.
I have had it looked at by mechanic guys i use regularly and they have all said its the high pressure fuel pump (not cheap) which i have replaced. It has made a difference however its still not right.
We are stuggling to get to the bottom of what it could be. There is no issue with the ignition system so its a fuel issue i would have thought.
Some ideas and help would be appreciated please???
Thank you ever so much
Rob
Rob
