S4 discs, pads and shocks
DiscoAudi
UK
Just picked up a 2013 S4 and I'm looking to refresh suspension and brakes. I dropped it into an Audi dealer for an oil change and inspection and it needs a couple of parts. Audi prices are absolutely nuts so looking to pick up parts online and get fitted by a local independent.
  • I'm looking for discs and pads reccomendation, I wanted to go down the Macan caliper route but with the suspension bits needed I'll hang on for now.
  • I need 2 rear shock absorbers, both leaking apparently.
  • "Lower straight arms" I've no idea what this is, it's under front suspension. Any ideas?
  • "Upper control arm bushes worn" - Also not too sure exactly what I need here.
Any help in avoiding the stealership would be great.
Reactions: audiwaterpump
Hi buddy.
Welcome to the joy of owning a S4.
1: Depends what power you are looking at getting stick with standard disks. Pads make all the difference so go for Ferodo or similar. Expensive but worth it.
2: The rear shocks are an easy job to do. You can get them from autodoc.
3: I changed the 4 bottom arms and they were a pain to do. There are two sets of arms, one set is bent (large) one set is straight. Easy to spot under the car. I would advise to got a full kit from autodoc again as no4 needs changing, they might as well change the whole lot. I would advise some one else to do it as PINCH bolts are utter ****!
The suspension arms will cost you quite a few bob to source and replace.
My went at around 50k so even standard audi parts don't last.
Good luck and hope you enjoy the car.
EBC discs and Red stuff, decent upgrade for the cost
Thanks I'll look into them.
Any issues with mixing performance pads / discs up front with OE replacements in the rear?
Sent from my SM-G988B using Tapatalk
Brembo discs and Redstuff here .
I'm thinking more EBC discs and red stuff pads up front and OE replacement pads and discs in the rear.
I think total cost was < £400 for the parts. I think OE rears with EBC fronts is sensible, that will lower your cost. The thing with Red Stuff is to follow the break in procedure, which I did to a T. If I was keeping the car forever I might go another route; such as GiroDisc's 2 piece rotors with G-Loc pads :)
Thanks, I'll keep the break in in mind.
11
873
