Don't know mate but it's a pita, first thing I do is push the button to turn it off once the car starts...it kicks in too fast even before you're 100% stopped at times!
Disabled mine with an add on, fits between switch and loom. Easy to fit remove switch pannel with keys, unplug loom connect socket and connect other end to loom removed. About £30 from aliexpress. Now works opposite, off all the time unless I select on.
Msg that you want it for A5 b9 it doesnt work as the advert it works as I posted. Off all the time or On when selected. https://www.aliexpress.com/item/4000980505012.html?spm=a2g0s.9042311.0.0.1f534c4d3D7vYq
