Hi I’ve recently replaced the turbo on my A3, car seems to be running spot until I go above 3000RPM in 5th or 6th gear, then it’s goes into limp mode. Not sure if this is significant but no engine management light comes on as I’ve read normally that’s happens when it goes into limp mode. I’ve had a mate put a reader on the car comes up with fault code P0234 overboost. Car drives fine in 1st to 4th can push above 3000RPM and have it not go into limp mode. Had some advise to check if the MAF sensor is blocked I took out and inspected it looked okay but got another one on order anyway.
I was wondering whether anyone on here has had a similar issue to mine and whether I could get some advise on what to check next if replacing MAF sensor doesn’t sort it out. Cheers
