Q2 SQ2 Dip Stick
Bigfoot
Member
Lincoln
I have only had my SQ2 a Month so I thought I would just check the oil level, however you cant pull it out as it has lugs either side to stop you. Do you break these off??
Maybe, like my 2.0 engine, it doesn't actually have one and the level is done by sensor. I would contact a dealership first before using any force...
I think I will check as I don't think you are supposed to yank it out But thanks
Reactions: cuke2u
Does your MyAudi app have the oil level displayed in it? If it does then a probably indicator that there is no dip-stick.
The same engine as the S3 isn't it? should just pull out. App compatibility with the Q2 is almost non existent so 99% sure it won't show oil level.
841
