Hello;
Recently, I tried to fix an issue with boot locking. I'll try to explain the problem.
Audi, A3 8l TDI, 1.9, 2001.
Boot lock was not working properly, so I removed the part over registration plates, there was issue with connector at the right side (for the opening switch), it was ruined, visibly, so I put wires, to it (no connector now), and the same for the other at the left side. I did take care to put everything to it's place (eft side switch was used to open boot, trunk, before the issue).
After that, I was not able to open doors using key fob, electric windows, both driver and passenger side, stopped working, sunroof does not work.
I have to lock and unlock both driver and passenger doors manually, using key. Unlocking driver's door is not unlocking passenger one. Sun roof not responding when moving the switch / button up there. Electric windows not opening when pressing buttons / switches on both sides. Strange things related to upper indoor lights, smaller ones are not being turned off at all, bigger lights are not switched on by opening doors. Those bigger and small lights can be turned on and off only by their buttons.
Communication, key fob works (key fob battery replaced 2 months ago, it did work properly for that time), there is a click sound when pressing lock / unlock at key fob, then orange lights do blink, so key fob seems working, but, no sound of pump mechanism starts, doors not unlocked / locked.
At the drivers door there is red security light at the edge, working, and green one, directed down, working as well. Wires from car body to door seems not to be broken.
The button at the drivers door for locking / unlocking all doors not working.
Fuse 14 checked, it is okay. I tried to disconnect (first minus then plus) car battery, then connect again (first plus then minus, as suggested), to see if the issue will disappear, it did not help.
Sorry for such a long explanation, just trying to say more details.
Anyone has suggestion, please?
