Good morning some pics would be useful to see in detail sounds like an issue I had worn return spring in handle mechanism. I suggest removing the door card checking the return spring and also the Bowden cable
It's what I said above check Bowden cable firstly but return spring is probably gone needs replacing have to remove door card then remove handle section and replace spring.
