Looking for info on where to start looking on how to fix my beloved A4 Avant CAHA 180 .... yesterday I thought it was sounding a little more TDi than normal but just put it down to paranoia , today on my 40 mile commute at 5:56 going off the LOG, the times compare, I heard what can only be discribed as a quiet screech I was on the motorway cruising at 70 and it was like i had gone over a different type of tarmac... car seemed fine if perhaps a little low on power but i wasnt pushing it ...then tonight on my return home I started getting glow lamp light flashing occasionally and the engine started to get even more more TDi like and I got the screeching again for longer this time and still less power, I nursed it and she got me home and still starts fine but sounds awful, like a tractor , so i pulled codes , my first thought was the high pressure pump but I've taken the filter off it and it's clean as a whistle and nothing fuel related in the codes ,,, here's the LOG
would a faulty sensor cause it to sound like a tractor ? Cambelt was done by myself around 20,000 miles ago but it seems to me it may have slipped or moved and what the screeching be ?
sorry for the long post, Regards Mark
Sunday,14,March,2021
Address 01: Engine Labels: 03L-906-019-CAG.clb
Control Module Part Number: 03L 906 022 RM HW: 03L 906 019 AL
Component and/or Version: R4 2,0L EDC H30 8422
Software Coding: 12194012243703080000
Work Shop Code: WSC 00732 210 88528
ASAM Dataset: EV_ECM20TDI03L906022RM A02005 (AU48)
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 0109EF6290C8204AAF-8054
4 Faults Found:
5306 - Throttle Position Sensor (G69)
P0122 00 [032] - Signal too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
4113 - Camshaft Position Sensor (G40)
P0341 00 [101] - Implausible Signal
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 243535 km
Date: 2021.03.14
Time: 05:56:23
Engine speed: 2107.50 /min
Normed load value: 69.8 %
Vehicle speed: 110 km/h
Coolant temperature: 69 °C
Intake air temperature: 14 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.160 V
Unlearning counter according OBD: 40
Engine start: start synchronization: EPM_MODE_OK
Epm st Sync: EPM_FULL_SYNC
Camshaft speed (RPM): 2563.8 /min
Epm Ca S phi Adap Ref Pos I1 mp 0: 126.15 °
Synchronous angle: -6.59 °
Epm Ca S phi Raw Value mp 0: 0.00 °
Epm H Cr S st Sig Mode: GAPFOUND
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [100] - Incorrect Correlation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Mileage: 243535 km
Date: 2021.03.14
Time: 05:56:22
Engine speed: 2119.50 /min
Normed load value: 67.5 %
Vehicle speed: 111 km/h
Coolant temperature: 68 °C
Voltage terminal 30: 14.120 V
Camshaft speed (RPM): 1060.8 /min
Synchronous angle: -7.05 °
7934 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 243647 km
Date: 2021.03.14
Time: 19:35:26
Engine speed: 827.00 /min
Normed load value: 44.3 %
Vehicle speed: 1 km/h
Coolant temperature: 78 °C
Intake air temperature: 11 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.200 V
Accelerator position: 0.00 %
Charge Pressure Actuator: activation: 99.87 %
Charge Pressure Actuator: acknowledgment: 94.30 %
Trb Ch r Drft Clsd mp: -19.85 %
Charge pressure adjuster status learning-Bit 0: 00000000
Charge pressure adjuster status learning-Bit 16: 00001000
Charge pressure adjuster status learning-Bit 24: 00110111
Charge pressure adjuster status learning-Bit 8: 00000000
Charge pressure adjuster position sensor: 2070.6 mV
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 243535 km
Date: 2021.03.14
Time: 05:56:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Mileage: 243535 km
Date: 2021.03.14
Time: 05:56:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 243647 km
Date: 2021.03.14
Time: 19:35:26
