Facelift Rear Diff oil change.
8YARWY
Electric Avenue
away
Decided not to let being In isolation go to waste and the sun is shining
Easy little job to do.
Jack up / lift the car so it’s level
Locate the fill / drain plugs.
Use a 5mm Hex to undo the fill plug first then the drain plug
Let the litre of Axle oil drain out
Nothing to see here
Fill up your chosen method of getting the new oil into the Diff, I use this Draper filling tool.
Push the end into the top fill hole and pump away until the litre is in the Diff.
Once you reach the bottom it’ll gently start to trickle out the bottom of the fill hole so stop and put the fill plug back in, clean up around the area of both plugs and you are done.
Reactions: CHRS3, hawesy25, RS3 S. and 3 others
You have all the toys Sean!
TX.
Reactions: 8YARWY
Lol.
Did the Haldex after the Diff
Will be doing the DSG and front diff this week too.
Great info’s mate thanks for posting..
(Any houses up for sale in your area) I’ve got lots for you to do if your bored lol
Lol
I think the car is over serviced as I’d done the Haldex and DSG at 15k already.
However being in self isolation means trying to keep busy
Reactions: RS3 S.
Lol
Cant harm anything a bit of over servicing! and as you say keeps you busy.
Lol.
Hi,is it the same oil for the haldex and the diff.or is there 2 different ones.?
Did the Haldex and DSG oil change at the dealers last November. I'm just curios, is the white DSG filter changed by default in the included DSG service, or did I had to emphasize that I want it changed too?
With Audi who knows...........
You'd like to think they changed it
Reactions: s3facelift09
I did the Haldex service at Audi (change of fluid) a few months ago, and since then the car developed a sort of a whine.
I went to an independent garage today, they pulled out the Haldex pump and cleaned it. This is how it looked (before cleaning :)):
Haldex1
Haldex2
