A4 B9 2017 Reverse camera retrofit
ChRoffey
Hi All,
I'm looking for a little guidance on finisshing off my reverse camera retrofit. I bought a genuine audi camera kit and fitted it as per the instructions. I've now come to code it in and I'm having issues. I've found lots on forums but nothing specific to the A4 B9 and other cars all seem to have slight differences. The kit came with an activiation pack which has a code, an activation numvber and a PIN. I called Audi and they say I need to to take it to them to get it working using the activiation pack and I won't be able to do it through VCDS. Is this correct or can I do it? I have VCDS and have already attempted with no luck. Any help is massively appreciated. Here's a scan:
Tuesday,30,March,2021,08:46:21:53320
VCDS --Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDSVersion: 20.4.2.0 (x64) HEX-V2 CB:0.4526.4
Dataversion: 20200730 DS317.0
www.Ross-Tech.com
VIN:WAUZZZF47HA141095 License Plate:KN17LXO
Mileage:193793km-120417mi Repair Order:
ChassisType: F4-AU49 (4M1)
Scan: 01 0203 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6C 6D 81
A5 AC BB BC D6 D7
VIN:WAUZZZF47HA141095 Mileage:193793km-120417miles
01-Engine --Status: OK 0000
02-AutoTrans -- Status: OK 0000
03-ABSBrakes -- Status: OK 0000
08-Auto HVAC-- Status: OK 0000
09-Cent.Elect. -- Status: OK 0000
15-Airbags-- Status: OK 0000
16-Steeringwheel -- Status: OK 0000
17-Instruments-- Status: OK 0000
19-CANGateway -- Status: Malfunction 0010
29-LeftLight -- Status: OK 0000
2B-Steer.Col. Lock -- Status: OK 0000
39-RightLight -- Status: OK 0000
42-DoorElect, Driver -- Status: OK 0000
44-SteeringAssist -- Status: OK 0000
46-CentralConv. -- Status: OK 0000
52-DoorElect, Pass. -- Status: OK 0000
5F-InformationElectr. -- Status: Malfunction 0010
6C-Back-upCam. -- Status: Malfunction 0010
6D-TrunkElect. -- Status: OK 0000
81-GearShift -- Status: OK 0000
A5-Frt Sens.Drv. Assist -- Status: Malfunction 0010
AC-ReductantControl -- Status: OK 0000
BB-Door RearDrv -- Status: OK 0000
BC-Door RearPass -- Status: OK 0000
D6-LightCtrl Left 2 -- Status: OK 0000
D7-LightCtrl Right 2 -- Status: OK 0000
Address 01:Engine (J623-CRTC) Labels: RedirFail!
Part No SW: 8W0 907 401 E HW: 059 907 309 F
Component: 3,0l V6 TDI H24 0003
Revision: C7H24---
Coding:122A403205260503240800000000000000000000000 00000
Shop #: WSC 55376 002 1048576
ASAM Dataset: EV_ECM30TDI0118W0907401E001003
ROD: EV_ECM30TDI0118W0907401E.rod
VCID: 392F280389D4964355D-806C
No faultcode found.
Readiness: 00 0 0 1
Address 02:Auto Trans (J217) Labels:* RedirFail!
Part No SW: 8W0 927 158 HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H05 1010
Revision: --H05---
Coding: 100000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
VCID: 7F5B061BD77078732B9-802A
No faultcode found.
Address 03:ABS Brakes (J104) Labels:8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Coding:14AA309930A60A97119E489A00825292E6A592280C0 C508812004A4967A549
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 49CF58C3D93406C3C5D-801C
No faultcode found.
Address 08:Auto HVAC (E87) Labels:* RedirFail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0090
Coding:2618002D5544440D020001008800000000000000000 00000000000000000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 372B2E3BBFC08033A39-8062
Fresh Air Blower Front:
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001351145
Relative humidity sensor in fresh air intakeduct:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 09A8049880PAG0MUFU02
Rear Climatronic Operating And Display Unit:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
No faultcode found.
Address 09:Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding:07501143E11800CD054D87145F2E00B9110B3108000 000000000000020001A810A450122025609
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 025D8FEFA482159B447-8056
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8W2 955 119 HW: 8V2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 161230 043 0813
Serial number: 89425300301636502499
Coding: 5BC7F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 20280443X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 06 07 2016 00741280
Automatic Day Night Interior Mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE120121611520967
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00274896
Convenience And Driver Assist OperatingUnit:
Subsystem 6 - Part No SW: 8W0 925 301BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000181100005
Coding: 000000
No faultcode found.
Address 15:Airbags (J234) Labels:|8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0103
Serial number: 003UP002U5Z1
Coding: AACCF0C00C800000585400F3D08C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005013
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 4CC161D7D64613EBFEB-8018
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 442 061 402 17
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00A12027093C42M
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 442 061 402 17
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00A1202709472CR
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 402 17
Component: SideSensor_Dr 1C7 0148
Serial number: 35177000C2A52B45C88G
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 0B1 402 17
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700102A52B48C4DA
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 102 17
Component: FrontSensor_D 1C5 014A
Serial number: 35575000429E1685B5EI
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 102 17
Component: FrontSensor_P 1C5 014A
Serial number: 35675000429E1686569A
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 102 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 23075002C2A4F336C7BI
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 442 431 202 17
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00AD2027092B200
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 442 431 202 17
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00AD21781B4518E
Coding: 2D2D2D
No faultcode found.
Address 16:Steering wheel (J527) Labels:4M0-907-129.clb
Part No SW: 4M0 907 129 HD HW: 4M0 907 129 HD
Component: Lenks.Modul H11 0009
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 79AFE803C954564315D-802C
No faultcode found.
Address 17:Instruments (J285) Labels:* RedirFail!-SRI2
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H17 0309
Coding:20A469D0288006000123E9600000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod
VCID: 42DD4FEFE402D59B047-8016
No faultcode found.
Address 19:CAN Gateway (J533) Labels:* None
Part No SW: 4M1 907 468 D HW: 4M1 907 468 A
Component: Gateway H16 0107
Revision: 4V010003 Serial number: 0344V01B417213
Coding:03010001000086407F0700000059001248100007000 000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002_AU73.rod
VCID: 38292D07B2DE8F4BAA3-806C
Multi Function Steering Wheel ControlModule:
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170218133148 21675
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 1520833204
1 FaultFound:
66304 -Databus
U1124 00 [008] - AdditionalInstallations Detected
[Data_Bus_Commponent_List_detected]
Intermittent - Confirmed - TestedSince Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 193792 km
Date: 2021.03.29
Time: 23:12:52
Address 29:Left Light (J1018) Labels:4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: 78A9ED07F25E4F4B6A3-802C
No faultcode found.
Address 2B:Steer. Col. Lock (J764) Labels:*5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000050968014
Coding: 8800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 323D1F2F54A2651B947-8066
No faultcode found.
Address 39:Right Light (J1023) Labels:4M0-907-397.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001012
No faultcode found.
Address 42:Door Elect, Driver (J386) Labels:*None
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0057
Serial number: 0000243187529
Coding: 001F8A204001000000001082
ASAM Dataset: EV_DCU2DriveSideMAXHCONT001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
No faultcode found.
Address 44:Steering Assist (J500) Labels:*None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41DF40E3E104CE831DD-8014
No faultcode found.
Address 46:Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0344
Coding: 013500002F110040630180000600080033020010004302502F 04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7EA5FB1FD07A717B20F-802A
Sensor For Anti Theft Alarm System:
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY170234BLT
Alarm horn:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000037713827
No faultcode found.
Address 52:Door Elect, Pass. (J387) Labels:*None
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0057
Serial number: 0000243779557
Coding: 001F8A204001000000001080
ASAM Dataset: EV_DCU2PasseSideMAXHCONT001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 4BC362CBD34814D3F71-801E
No faultcode found.
Address 5F:Information Electr. (J794) Labels:*8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 C HW: 8W5 035 035
Component: MU-P-LND-EU 033 1329
Serial number: A829B0HB012988
Coding:01940201FF0A000013111101000A00332F0002E7017 00100DE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 802DF HW: -----------
Component: ECE 2019/2020 --- 0177
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9HBK00FRH
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK124011700040779
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800EG HW: -----------
Component: Gracenote2 --- 1015
1 FaultFound:
7179 -Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Rear-view camera (0x0B) - functionrestriction due to communication error - BapErr_retry not successful]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 193792 km
Date: 2021.03.29
Time: 23:13:11
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 02
Address 6C:Back-up Cam. (J772) Labels:* RedirFail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H18 0250
Coding: 0000000000000000000000
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 33331A2BABB86C139F1-8066
3 FaultsFound:
10490624 -No End-of-Line Programming
B2013 00 [009] - -
[ECU no DataSet]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 193792 km
Date: 2021.03.29
Time: 23:13:35
OFF
13636352 -Control module not coded
U1013 00 [009] - -
[ECU not coded]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 193792 km
Date: 2021.03.29
Time: 23:13:35
OFF
10489856 -No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 22
Mileage: 193792 km
Date: 2021.03.29
Time: 23:13:35
OFF
Address 6D:Trunk Elect. (J605) Labels:|5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31219653000000
Coding: 0550
ASAM Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_VW37.rod
No faultcode found.
Address 81:Gear Shift (J587) Labels:4MX-713-041-81.clb
Part No SW: 8W2 713 041 K HW: 4M2 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170221000362
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
VCID: 3C21311786E6A36B4EB-8068
No faultcode found.
Address A5:Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding:0404090200000403024023A0A50000FC00F0C020C00 0
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3B23320B83E8A453471-806E
4 FaultsFound:
1122664 -Databus
U1121 00 [008] - Missing Message
[TIMEOUT_PSD_04]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 193792 km
Date: 2021.03.29
Time: 00:00:49
Control Module temperature: 21 °C
Voltage terminal 15: 11.30V
1123714 -Databus
U1123 00 [008] - Received ErrorMessage
[Airbag_01_AB_Systemfehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 193792 km
Date: 2021.03.29
Time: 00:00:52
Control Module temperature:22 °C
Voltage terminal 15: 11.40V
1123600 -predictive route data
B1630 02 [008] - Signal Failure
Intermittent - Confirmed - Tested SinceMemory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 61
Mileage: 192913 km
Date: 2021.03.13
Time: 15:21:14
Control Module temperature:25 °C
Voltage terminal 15: 13.00V
1123601 -predictive route data
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 54
Mileage: 193188 km
Date: 2021.03.17
Time: 17:42:56
Control Module temperature:29 °C
Voltage terminal 15: 13.10V
Address AC:Reductant Control (J880) Labels:4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 303915275AAE570BE23-8064
No faultcode found.
Address BB:Door Rear Drv (J388) Labels:* None
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0057
Serial number: 0000243807153
Coding: 000F88200001000000001080
ASAM Dataset: EV_DCU2RearDriveMAXHCONT001005
ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
VCID: 4EC56BDF205A21FB90F-801A
No faultcode found.
Address BC:Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 005 0057
Serial number: 0000243807366
ASAM Dataset: EV_DCU2RearPasseMAXHCONT001005
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
No faultcode found.
Address D6:Light Ctrl Left 2 (A31) Labels:7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_AU37.rod
VCID: 1675C3BFD80A993B98F-8042
No faultcode found.
Address D7:Light Ctrl Right 2 (A27) Labels:7PP-941-572.clb
Component: LED1R H09 0003
ASAM Dataset: EV_LEDModRightMELCOAU736001004
No faultcode found.
End----(ElapsedTime: 01:49, VBatt start/end: 11.4V/11.3V. VIgn 11.4V)-----
Hey I can’t personally answer your question but ping an email to Andy at Audi Upgrades and I’m sure he will be able to guide you.
You have purchased and fitted a genuine Audi retrofit kit which can be coded via Audi using the enclosed codes or a specialist using 3rd parts software.
if in or around London I can complete this for you officially.
Hi
Thanks for the offer but I'm in Devon so a bit out of the way. Audiupgrades.co.uk are helping me out remotely
So, all sorted, thanks to Andy at audiupgrades.co.uk
Genuine cracking bloke and fully recommended.
Awesome glad he sorted you out. Genuinely is a good guy
Was your loom anything like this ?
Steve.
Do you mind sharing the latest full scan of your car?
I am having some difficulty like yours too.
Would want to compare the codes.
Hello, I fitted the genuine kit myself via instructions. The car then had to be coded via odis to activate the camera. Could not code it with vcds.
