For Sale Forge Inlet Hard Pipe for Audi RS3 8V facelift
FBF01
Edinburgh, Scotland
As above.
This is £178.49 new.
£75 inc postage Via PayPal
Very good condition. New car arrives end of the month hence sale.
Some further info below.
The Forge Motorsport high flow intake pipe for the Audi RS3 8V face lift and TTRS 8S, eliminates the highly restrictive plastic inlet pipe by increasing the inlet bore diameter from 70mm to 89mm outer diameter. This increases air flow and maximises the volume of air being forced into the engine, improving efficiency and performance. The FMINLH8 is designed for use with the standard airbox and works superbly with a performance panel filter. This modification can equate to increases of up to 10hp on mapped vehicles which is a remarkable gain for an easy to fit bolt on modification.
  • Works flawlessly with the OEM airbox giving improved throttle response and power gains throughout the entire rev range
  • CNC mandrel bent 90mm alloy pipe and brackets welded and manufactured in the UK by experienced fabricators
  • Powder coated in satin black for that OEM factory look
  • Custom silicone couplers for an easy fit
  • The Forge silicone hoses in this kit have been designed to include an expensive inner liner of modified silicone known as Fluorosilicone
  • This means the hoses are suitable to be used with either modern long-life coolants, Organic Acid Technology coolants (O.A.T.) or air containing oil mist
  • The construction of the hoses has been engineered to exceed that of the OEM fitments, and will enhance any engine bay both technically and aesthetically
  • The use of a Fluorosilicone liner ensures that Forge silicone hoses are the clear market leader
Pics
Hi mate, do you know if this fit the non facelift 8v S3
Totally different engine mate.
Curious to know if it fits a 2016 RSQ3 though?
Any idea what the difference in fitting is between a face-lift and non face-lift RS3.
Also did you notice any performance gains or induction noise?
*EDIT* just seen the original thread date so I guess you may not have it anymore!
I’ve got a forge one for sale but it’ll only fit the Daza engine.
Reactions: -Ju-
That should mean something to me but it doesn't lol
I'm guessing that's the facelift engine?
