Help identifying gearbox/propshaft part
stevenage
Can anyone help identify this part highlighted? A part number would be ideal and any info on how this might be fitted would also be very helpful.
The issue is that aluminium housing is detaching from the rubber, causing vibrations.
Thanks in advance.
Edit: 6 speed, Quattro, 2.0 TFSI
20210413 091307
20210413 091131
20210413 091127
Thanks in advance.
U
You might be able to use this site to locate what you need
Have used it myself before
U
Have used that before and it's pretty decent. But not having much experience with gearboxes and props means I'm a little blind on those exploded diagrams.
Will research all the same - nice one.
Is this the bracket holding the prop to the body of the car?
You can see the play in the vid of that particular part. Which is what the mechanics have identified.
Yep in the centre
Check my build thread out - I got a uprated bearing carrier from JXB performance
(yet to install)
Yep in the centre
(yet to install)
Thanks Bobby - will certaibly check that out. Although I'd hope/expect the mechs to have dismissed that as a cause through their inspection.
Any idea what that part might be, BTW....part 8 on this image perhaps?https://audi.7zap.com/en/rdw/audi+a4+avant/a4/2013-736/4/409-409080/
SmartSelect 20210413 223753 Samsung Internet
Its a balancer
Hey Bobby,
i've picked up the part from Audi, images below. Any idea how this fits to the gearbox and propshaft? The part is splined at both ends and on the gearbox side there is a sharp narrow groove, perhaps for a retaining clip? Also not sure how the fitted one would be removed.
Grateful if you can share any insight - thanks,
20210422 08095220210422 08100020210422 08100620210422 08103520210422 081055
