Hey guys my car has come up with the DPF light, coil light and check engine light. It is in limp mode now.
I have taken the DPF off and sent away to be professionally cleaned then done a regen. It was running good and then after 50ks the DPF light came back on shortly followed by the coil and engine lights. I done the glow plugs and the DPF sensor followed by a regen and again after 50ks or so the same problem occurred.
I am all out of ideas to what it could be I’m thinking possibly the turbo could be on its way causing it to heat up to much and put the car into limp mode? Has anyone done the things I have done and still had the same problem??
I can’t provide any fault codes at the time of writing up this post either, sorry.
