abs long coding
Sufister
Peterborough
Monday,28,June,2021,19:26:15:31334
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ8P3AB030986 License Plate: PARVAZ AUDI
Mileage: 155430km-96579mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 61 62 72
VIN: WAUZZZ8P3AB030986 Mileage: 155430km-96579miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
Component: R4 2.0l TDI X21 9979
Revision: 41X21--- Serial number: AUX7Z0J3FNT05L
Coding: 00190012040501080000
Shop #: WSC 43278 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018AB 003012
ROD: EV_ECM20TDI01103L906018AB.rod
VCID: 6ADBB5BD8D058FDB7D-803E
4 Faults Found:
4638 - Engine Oil Temp. Sensor (G8)
P0196 00 [039] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 155436 km
Date: 2021.06.18
Time: 00:11:11
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 49 °C
Intake air temperature: 22 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.740 V
Unlearning counter according OBD: 40
Fuel consumption: 0.00 l/h
Engine oil temperature: 61.9 °C
Oil warning threshold: 11.976 mm
Control Module temperature: 17.7 °C
Oil fill level: 0.000 mm
Outside temperature: 15.5 °C
Fuel temperature: 25.2 °C
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 155436 km
Date: 2021.06.18
Time: 00:00:40
Engine RPM: 423.00 /min
Normed load value: 100.0 %
Vehicle speed: 255 km/h
Coolant temperature: 34 °C
Intake air temperature: 19 °C
Voltage terminal 30: 9.900 V
Throttle valve adapter: specified value: 100.00 %
EGR Solen.val.: actual value: 100.17 %
Charge air pressure: specified value: 598 hPa
Charge air pressure actuator: acknowledgment: 13.84 %
Air mass: specified value: 706.5 mg/stroke
Air mass: actual value (mg/stroke): 3276.7 mg/stroke
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 31:63:63
Coolant temperature: 33 °C
Voltage terminal 30: 12.620 V
ACC control module: received status-Bits 0-7: 0
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 0.000 m/s²
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
12888 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 155436 km
Date: 2021.06.18
Time: 00:14:58
Engine RPM: 827.00 /min
Normed load value: 24.7 %
Coolant temperature: 57 °C
Intake air temperature: 21 °C
Voltage terminal 30: 15.040 V
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 00028 028 00001
VCID: 7AFB85FDF5A53F5B8D-802E
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 254
Time Indication: 0
Date: 2021.06.18
Time: 00:11:46
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 53504
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000486 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78FF9FF50BA92D4BFB-802C
5 Faults Found:
01592 - Air Quality Sensor (G238)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 155434 km
Time Indication: 0
Date: 2020.12.02
Time: 20:55:28
Freeze Frame:
Temperature: 4.5°C
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 9
Reset counter: 254
Mileage: 155434 km
Time Indication: 0
Date: 2020.12.08
Time: 00:30:37
Freeze Frame:
Temperature: 0.5°C
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 5
Reset counter: 35
Mileage: 155435 km
Time Indication: 0
Date: 2020.12.11
Time: 19:10:29
Freeze Frame:
Temperature: 7.5°C
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 10
Reset counter: 254
Mileage: 155435 km
Time Indication: 0
Date: 2021.03.05
Time: 17:32:02
Freeze Frame:
Temperature: 4.0°C
Voltage: 14.00 V
RPM: 1000 /min
Load: 0.0 %
Load: 9.0 %
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 38
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 7.70 V
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB005F0C0207041E00000015C431A29AA004DC12AE4008F800041
Shop #: WSC 00046 412 00000
VCID: 326B6DDD6D55071B05-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
5 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:14:57
Freeze Frame:
Term 15 On
Voltage: 14.60 V
ON
ON
Term 50 On
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:18:55
Freeze Frame:
Term 15 Off
Voltage: 8.05 V
OFF
ON
Term 50 Off
OFF
OFF
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:18:55
Freeze Frame:
Term 15 Off
Voltage: 7.55 V
OFF
ON
Term 50 Off
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:18:58
Freeze Frame:
Term 15 Off
Voltage: 8.75 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:19:22
Freeze Frame:
Term 15 Off
Voltage: 7.65 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB006ZUCQ
Coding: 30314238303830303037554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 4FAD042916A74AF30A-801A
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000B2648AF%
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB40000B48CAA43
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400005778398M
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB4000057781C5L
Crash sensor for front airbag: driver side:
Serial number: 35547RB4000058C2CBE1
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB4000058C2CED4
2 Faults Found:
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Date: 2021.06.18
Time: 00:11:02
13636864 - Control Module for ABS Brakes
U1015 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Date: 2021.06.18
Time: 00:15:01
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0002012
VCID: 4683210D31DD8BBBB9-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H04 0100
1 Fault Found:
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2243J005024527
Coding: 0004428
Shop #: WSC 12345 067 57207
VCID: 408F371513F9A58B83-8014
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:19:15
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:19:55
00562 - Sensor for Oil Level/Temperature (G266)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 254
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:05:26
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J1042702B7
Coding: E9807F06100202042103
VCID: 6BD5B0B94AFF96D306-803E
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 38
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:14:59
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:20:06
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03005 Serial number: AUX7Z0J3FNT05L
No fault code found.
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0131764
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 00046 000 90108
VCID: 316962D1A8533C037C-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:14:57
Freeze Frame:
Voltage: 14.38 V
DU
Temperature: 21.0°C
RPM: 832 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Count: 0
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158068115400
VCID: 366351CD413D1B3B29-8062
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:20:05
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 39
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:19:26
Freeze Frame:
Temperature: 19.0°C
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0131764
VCID: 479D2C0936D792B342-8012
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z3K6036727
Coding: 0310011
VCID: 428B3D1D1DF5B79B95-8016
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 254
Mileage: 155436 km
Time Indication: 0
Date: 2021.06.18
Time: 00:00:11
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J1042702B7
Coding: 0303085A
VCID: 68DFCFB59B09BDCB6B-803C
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650169777
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 00046 412 1012544
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 4385381902EFBE939E-8016
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 04:38)--------------------------
What's your question?
Reactions: George Kost
