Sold AUDI S3 8P 2009 STG 2+ 360bhp 545NM
Not open for further replies.
Alex.S3
Suffolk
ABlake photos  DSC4554
More photos here www.ablake.photos/audis3
Price £11,998
Located in Ipswich
The car is an animal with 360bhp and 545nm, the car was tuned by NVM to stage 2+ with supporting DSG map. With the 4wd you'll find it puts the power down surprisingly well (I'm sure if you are reading this here you already know this).
It’s had no expense spared in it’s lifetime, in my ownership I’ve had the following carried out cambelt, water pump, Haldex service with filter, cam follower (98k). There's also a massive folder full of receipts.
The car has had the wheels refurbished recently along with 2 new Pilot sports fitted (August 2021). As I’m a stickler for things being right I got the front wings were resprayed as they showed signs of rust on the inner lip (April 2021).
Although the car does have 100k on the clock the body work is in brilliant condition, with it being regularly waxed by me using EZ Ceramic Wax.
I suspect you would be looking at close to 5k to build a car to the same spec and condition. Essentially a well maintained and sorted car!
Specs as follows:
Engine:
AutoTech HPFP
R8 CoilPacks
RS4 FRV
AirTech Stage 2 FMIC
AirTech charge hoses
Neuspeed cold side kit
BLOX 2.5inch velocity Stack
BLOX Oversize filter
TTS Engine Cover
PowerFlex solid lower engine mount
Rev G Diverter Valve
Aggressive ramp Stage2+ Tune from NVM
Active overrun (4-6k rpm)
Stage 2 DSG tune
Launch control (4k rpm)
Miltek 3” un-resonated T-back exhaust
Miltek 3 inch d/pipe with sports Cat
Suspension:
KW V1 Clubsport coilovers
Front and rear H&R anti-roll bars
Power flex bushes
Brakes:
EBC drilled and Grooved discs F&R
EBC ultimax pads
General:
Global Telemetrics tracker which can be transferred to a new owner
Apple Car play/ Android Auto KENWOOD DAB DMX7017 with DAB
Cruise Control
Heated Seats
Font tyres Michelin Pilot Sport new, rear Good Year Eagle F1s 5mm
Reactions: Kayobong
