Rear caliper swap. Squeaking cured.
8YARWY
Electric Avenue
away
For a while I’ve had an intermittent rear caliper problem that was a rotational squeak when off the brake pedal.
At first it would only happen when hot but as time progressed it started to get more frequent.
After fitting the DBA pads I discovered a leaky seal, which made me wonder if this was the cause, so I took the caliper off and stripped it down, fitted a new seal & bled the line.
All good for 4 days then it returned, although not as severe.
So I decided to ring Audi for a price for a new rear caliper, price is……….£ 800 complete
Could have bought the caliper body for £270 but if it was a motor issue then I’d still be in need of that at £440 on top.
Did some ringing around and found a ‘specialist’ EPB refurbishing company, order placed and then these turned up
This was what was promised
So boxed up and will be sending them back.
I then found a brand new Vag EPB caliper in silver but not OEM, so went to brakes international in Rochdale and bought it.
I had intended to paint it gloss black but decided to transplant the internals instead.
So it’s basically had a new piston (with much thicker walls, see image above) new screw / slider mechanism inside, new seals everywhere and a new motor.
Hopefully this has cured it.
Price for the aftermarket caliper, £149.
Reactions: jimojameso, Cheggers, DW81 and 5 others
62
11K
9
3K
