Been having issues with temp for last few months so been working my way through possible causes and thinking now it might be thermostat. When sat in traffic and not moving the temp goes above 90 and on a few occasions has maxed out at 130 on temp gauge. Previous had OBD readings which also confirms its getting at high at 125 at times. I've replaced coolant temp sensor, have new cambelt and water pump and confirmed both fans work while car is running - they also spin for quite a few minutes after the car is turned off after a decent journey and or hot day. I have no leaks and all is otherwise ok so could it be the thermostat is stuck closed so coolant is not actually circulating through the car? Could it be checked anyway (VAGCOM?).
