Facelift Only one of my windscreen washers is working?
Aaron_m
Member
Belfast
Hi guys
I was hoping someone could help me,
I just recently got into my car and noticed the driver side of the windscreen was dirty, so I went to use the windscreen washers and only the passenger side shot out the water. I’ve listened to check if the motor was running and it was. So I don’t know what could be causing this, maybe a blockage?
(Audi A3 2016 facelift model)
Just get a needle & work back & forth in the hole, if fan version fitted, should be much the same.
Sorry don't like nhn said either use a needle or Google it loads of vids
It’s quite tricky to get at with a needle, is it best with bonet open or closed?
I just pop mine out from the bonnet, disconnect the tube, and the cable, and then work a bit of network cable into each nozzle.
673
172
16K
14
