Hello,
I recently aquired a 2014 A3 3x S-Line limousine/saloon/sedan with many options, of which for this topic, these might be relevant:
MIB 1 High system
Parking sensors front + rear
Rear camera (I assume the high module, didn't cross check the part number)
The dealer I got the car from did say that the camera didn't work and he said that the official Audi dealer said that the camera itself must be replaced.
The VCDS error is as following:
On the display I can still use the parking sensor view, but when I press the bottom left quadrant of the silver buttons to open the camera view, it does nothing (as expected).
How can I best tackle the situation? Any easy access to the wiring from start to end to measure continuity with a multimeter?
MIB 1 High system
Code:
Address 6C: Back-up Cam. Labels: 5Q0-907-441.clb
Control Module Part Number: 5Q0 907 441 A HW: 5Q0 907 441 A
Component and/or Version: MQB RVC Mid H07 0140
Software Coding: 027300010301000700
Work Shop Code: WSC 06385 790 00016
ASAM Dataset: EV_2CamSysRearPASE 006016 (AU37)
ROD: EV_2CamSysRearPASE.rod
VCID: 306FA5C76B235A09F2-8064
1 Fault Found:
9661203 - Cable for Video Signal from Rear View Camera
B136B 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 118
Mileage: 178769 km
Date: 2021.11.01
Time: 12:08:21
passive
