Looking for the name of this part
Iver
Kirkenes
There is a metal rod going to an electrical component between the two left rear control arms. Mine is broken and I'm looking to order a new one. I found this pic from a tutorial that shows some of the part. I'm away from home and looking for the part number.
Any help would be greatly appreciated.
That arm is used for the headlight level sensors.
PNs for front and rear below:
S3 Headlight Level Sensors
Ebay it or remove unit & repair, could drill into each end, fit a pin, smaller rod, threaded screw with head cut of, inside both ends with 2 pack resin or superglue, make sure the ends break lines line up, leave for a day, refit & test.
