I'm not even sure I've known a way to disable the chime on a B7 tbh, so its more than likely either a door lock issue or the cluster has a fault.
Ideally you 1st need to put on diagnostics & do a test on the chime itself in instruments module, if it doesn't work in test, then its a cluster repair or replacement usually, unless someone knows the chime disable coding.
