Hey guys,
After some advisory ... again
Scanned the car today with VCDS and got this 01858 error from HVAC module.
Googled it but not much found about it, only info that the sensors are in the vents, behind centre console.
Took the centre vents console out and noticed a little circuit board with two potentiometers attached to each vent opening/closing mechanism but no sensors. Unless they are the ones?
Right hand side one was not operating well for few some time but wasn't fussed about it, as knew it may be the mechanical fault.
Now, it turns out the cog from the potentiometer cannot be turned properly by the mechanism gear and that might be the issue scan was showing.
Is that the correct problem I found?
Did anyone experienced such issue and managed to resolve it?
