couple of questions
truebrummie
birmingham
i have two questions to ask
1... some time when i insert the key into ignition turning to start engine i have trouble with the imobiliser de activating
some times it deactivates straight away.
but then another day it could take several trys to de activate
any ideas on what this could be
2.... i have oil in my pipe work to and from the intercooler
why ?
1. The reader coil is playing up which is a common problem with A4's, there is a DIY fix if you do a search, but try adjusting the steering column up & down.
Mine did this for a few months then the problem went away.
why ?
if your car came with spare keys try those.
i had similiar problem i put the key in turn it and the car would just cut off! even if had my foot on the accelerator nothing worked.
every garage giving me a different answer, some saying immobiliser, some saying ignition coils. in the end it turned out to be just the key!
try that first.
hope it solves your problem.
Dan
thanks guys tried spare keys same problem with those
but will try the wire position and do a self fix search
any ideas on the other problem with the oil in my intercooler pipe
875
844
14
894
jbh
924
