Hopefully a quick one. It's a 3.0 tdi 2008 A5.
I had oil level sensor fault come up, so got the sensor swapped out (along with oil change), but still have the fault.
If I was to get another sensor and connect it up (so the sensor is just dangling in the air) - If it turned out that the initial replacement was faulty then I'd see a different fault wouldnt i? (low oil level warning, not sensor fault).
If I still get the fault then obviously would point to a wiring issue..?
Cheers, Adam.
Cheers, Adam.
