Hi mate, where are you based and can you pm with a quote? CheersWe've done this for 8p clients, if interested, then ping me a WhatsApp, prerequisite you have electric folding mirrors already, of course if you don't, we can fit these too.
Ping me a WhatsApp 07974994143Hi mate, where are you based and can you pm with a quote? Cheers
Contact @NHN on the number on his profileHi mate, where are you based and can you pm with a quote? Cheers
Folding mirrors when flashed with vcp will lock on long press on key fob as u said but they only unfold when key is put into ignition not when door opens .It can be done but you'll need VCP, can't be done with VCDS
They will fond if you long press the lock button, like when the windows close. They can unfold either when opening the drivers door, or when the ignition is turned on
It can be either. I have done both to TTs and Golfs. Any Gen3 door module should be compatible so that includes A3s depending on the moduleFolding mirrors when flashed with vcp will lock on long press on key fob as u said but they only unfold when key is put into ignition not when door opens .
You can code either with door open or via ignition with vcp budFolding mirrors when flashed with vcp will lock on long press on key fob as u said but they only unfold when key is put into ignition not when door opens .
Thats a new 1 to me unfold when opening door my bad .You can code either with door open or via ignition with vcp bud
My bad mate never knew they can be coded to unfold when door is open . Will need to stick my cable on and see if i can change mine as my drivers door module P has been flashed with Vcp .It can be either. I have done both to TTs and Golfs. Any Gen3 door module should be compatible so that includes A3s depending on the module
Note near london mate many many miles away . Will just have to leave it the way it is then , unlock on ignition . Cheers for replyVCP I'm afraid, VCDS cannot change the eeprom. OBD11 can I think but I don't have that. I have a guide on the TT Forum, I'll link it when I'm home. Are you near London?
Rough price on replacing motor and coding? Was quoted £250 at a garageWe've done this for 8p clients, if interested, then ping me a WhatsApp, prerequisite you have electric folding mirrors already, of course if you don't, we can fit these too.
