Hi, just after a second opinion on a strange issue with my car ( 2011 140ps 2.0 Diesel )
Just over a week ago I got symptoms of the slave cylinder failing when I got in the car for work, I pushed the clutch pedal down and 3/4 of the pedal did nothing but the last 1/4 worked and let me get he gear in.. worked like this for 1 day.
Then the pedal kept sticking to the ground ( pull up with my toe but could not use the clutch till I pumped it a couple of times )... then worked about 70% normal once the car set off...... now slowly the clutch feel has been getting better and better and now it feels completely normal and has been perfect for the past 2 days.
my problem is that I have had the car booked in to a garage since the problem occurred and its due in on Wednesday.... however im starting to wonder if it could be as simple as something like brake fluid change... the cylinder is not leaking as its lost nothing ( although its very dirty ) and i would have thought if it had failed then it would not magically start to work again.
In my head there is only the master cylinder, slave cylinder, a non return valve ( dunno where this is but garage told me my car has it ), and the fluid.... other than the actual clutch itself.
any second opinions would be very welcome as it would be great to avoid the estimated £800 for slave cylinder and clutch replacement if its not needed.
Cheers guys
Cheers guys
