So, car is a 2014 with the CREC engine on about 54k, has an MRC stage 2 with crank pulley, running 470bhp.
Last week after my normal 30 mile drive to work I noticed a little vibration at idle, scanned with VCDS, showed no codes.
Took it out for a bit of a more spirited drive, logged a cyl 5 misfire, swapped plugs/coilpacks around, misfire stayed on cyl 5. Compression test came back at 150psi for cyl 4 & 6, cyl 5 only 75 psi.
Leakdown test shows valves are all sealing correctly, also with the charger off looking into the ports it all looks very clean. Air is escaping into the crankcase. So it's got to be either rings or a piston issue. Surprising considering its only done 54k miles.
Car is currently at my mechanics 3rd in the queue for a rebuild
Anyone else had similar issues? What were the causes?
Also while it's bits what else should I have done? I don't want to get it fixed and back on the road only for something else to go in a few weeks time.
Other than PCV, waterpump and thermostat is there anything else worth doing?
