Hi. I was hoping to add the following sub to my 2015 S3 Saloon. I'm not an audio expert but handy enough that I reckon I can manage such an install.
My expectation is that there should be a connection available on the back of the unit in the glove box for this sub and that it will simply just work with the standard audio system. I am happy just to control the bass directly on the sub I know this won't integrate with the Audi system settings and don't care about that.Can anyone tell me what sort of connector or wire that I'll need to use?
Pioneer TS-WX130EA Subwoofer
- Maximum power: 160 W
- Nominal input power: 50 W
- Frequency response: 40 - 200
- Sensitivity: 98 dB
- Woofer material: Aluminium
- Voice Coil type Copper Round Wire 4-Layers
- Voice Coil bobbin type Glass Imide
- Lowest resonance frequency: 32 Hz
- Strontium Magnets
- Weight: 3.2 kg
- Dimensions (WxHxD): 280mm x 200mm x 70mm
Space Saving Active Subwoofer with built-in Class-D Amplifier. Easy to install thanks to its small footprint. (160 W) "Powerful Bass, without losing space. Pioneer launches another product in its generation of Class-D amplified subwoofers. Producing 160 Watts of strong, rich, deep bass that you can feel; without giving up space. With amplifier adjustments directly on the product itself, users can easily control and customise the bass output. Users can easily mount the TS-WX130EA under the front seats or in the boot.
Thanks to the inclusion of Class-D technology, Pioneer’s TS-WX130EA is even easier to install as it is capable of taking both High (Speaker Line Input) and Low (RCA Line Input) input signals. This means you can connect it to your aftermarket or original factory fitted stereo, to easily upgrade the sound you have now. TS-WX130EA is a small active subwoofer in a sealed enclosure, delivering 160 W Maximum power and 50 W Nominal Power.
