Hi guys looking to see if anyone can help out. I have a 2010 S3 8P sportback and my n/s/r door has started playing up, door doesn't lock/unlock through the central looking and the window doesn't work either.
I have had an auto spark look at it he has said that there is no power coming back out the control module running to the door lock, once he plugged the window switch back in the window started working but again lock doesn't work. we pulled the panel off the o/s/r door just to double check the signal coming out the control module and all is fine there.
we have checked the wiring looms going into the doors in the rubber sleeves and all is good at that side, question is, is there anyone local to Glasgow area who could confirm this through VCDS and even store the program and I can change out the control module if I get a new one then reprogram the new module
Thanks Paul
Thanks Paul
