Automatic EPB when put in Park
Bennnz
NZ
Hi all,
i have a 2015 A3 without auto hold. What I want to automatically activate EPB when the gear is put in park.
Auto EPB works if the car is in gear and door is open. But is there is code in VCDS that can enable the feature for when in P?
As far as I'm aware auto EPB can only be activated in P when you have hold assist. Try reaching on Ross-Tech forum or the various Golf mk7.5 forums as they tend to play more with VCDS than us Audi mk3.5 folk.
Reactions: nothingness
Hi all,
Here’s the coding, but pretty sure you need auto hold.
**Enable auto handbrake when shift into P
[53 - Parking Brake]
[Security Access - 16]
Code displayed to me was - 78713
[Adaption - 10]
"Shift P to EPB"
Set to Activated
Do It!'
For some reason it can’t c
[Adaption - 10]
"Shift P to EPB"
Set to Activated
Do It!'
It doesn’t seem to be able to connect to 53- parking brake. It times out . Under installed modules I don’t see 53 but only ABS . Is there a special way to connect to 53?
