Needle sweep
DavidA3
Romania
Can i do needle sweep for this intruments ?
Sunday,12,June,2022,17:21:13:00233
VCDS Version: Release 21.3.0 (x64)
Address 17: Instruments
Control Module Part Number: 8P0 920 932 D
Component and/or Version: KOMBIINSTR. VDO H02 0980
Software Coding: 0004051
Work Shop Code: WSC 80093
VCID: 356194D35C419F2320-8060
Advanced Identification
Serial number: 2245I002005746
Identification: VDD-024
Revision: D0H02002
Date: 08.06.09
Test stand number: 7601
Manufacturer number: 0610
Flash Status
Programming Attempts: 1
Successful Attempts: 0
Programming Status: 10000000
Required Conditions: 00000000
Flash Tool Code: 08256 386 00000
Flash Date: --.--.--
Misc.
Hardware number: 8P0 920 932 D
Lot Number:
Type Lock: VDD-
Car Info
Chassis Number: WAUZZZ8P3AA014261
VCDS Info:
Labels: 8P0-920-xxx-17-MY8.clb
Revision: D0H02002
Date: 08.06.09
Flash Status
Misc.
Lot Number:
Type Lock: VDD-
Car Info
VCDS Info:
You should be able to, you need to edit the eeprom on the cluster itself. You need to activate the options for them to be available in VCDS for activation. It's all done by editing the eeprom of the cluster and changing a few parameters. There's info online.
Reactions: DavidA3
u can help me to do this ?
I can point you in the right direction, if you don't have electrical knowledge, you can mess things up. Don't forget that the IMMO system is located where the instrument cluster is, you could possibly mess it up, which would end up costing a lot. You need to disassemble the cluster to get to the PCB, and then using a clamp connect to the eeprom with e.g. CH341, edit a few addresses, then activate everything through VCDS if needed.
Reactions: DavidA3
it looks great at first and then after awhile, you rarely notice it. To reprogram is not very hard but it a fair amount of work for something that is rarely noticed after weeks of use. as said above, you need to tear apart the cluster, use an eeprom coding device(not cheap considering its a one time use) then reprogram via VCDS. I've had this feature on two other audi's and frankly it bugs me so I turned it off. I generally advise against this mod but to each their own
Reactions: DavidA3
I thought it was easy to do but now I realize how much work it takes for something insignificant.
10
3K
17
Pii
30
21K
