Hello friends,
I would like to get help for fixing few problems on my Q7 2007 3.0TDi
From log (posted below) I deleted known or non priority faults (like open antennna etc).
1. What is important to say, I found disconnected connector to the ACC. After plugging in, radar appeared but still was showing "not available" on dash but no faults stored in the unit . After a test drive, there appeared error with front radar heater "open or short" but everything is plugged and after deleting the fault, ACC is clear without faults but still wont work.
2. second issue LDW. It appears like faulty slave unit for the LDW. What is the correct part number for LDW slave unit (when i tryed flashing the unit I got the error that slave is faulty)?
3. everything else - can you take a look at other faults and suggest some actions please? I do not know where to even begin since there are so many faults...
00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 13-Auto Dist. Reg -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4L0 910 401 K HW: 4L0 907 401 Component: 3.0L V6TDI A000AG 0030 Revision: --H03--- Serial number: Coding: 0011775 Shop #: WSC 31414 790 00001 VCID: 2A0CF29270FE857BB1B-807E VINID: 9D196AAAA11CA075001071832082831040 1 Fault Found: 005673 - Powertrain Data Bus P1629 - 001 - Missing Message from Auto-Distance Controller Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 36 Reset counter: 255 Mileage: 188585 km Time Indication: 0 Date: 2022.07.17 Time: 12:45:29 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 11.32 V Bin. Bits: 00110000 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.clb Part No SW: 09D 927 750 FK HW: 09D 927 750 FK Component: AL 750 6A 0940 Revision: 00H52000 Serial number: Coding: 0000001 Shop #: WSC 98765 666 38807 VCID: 7CA004CACAEACBCB937-8028 1 Fault Found: 18272 - Powertrain Data Bus P1864 - 000 - Missing Message from Auto Distance Controller ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb Part No SW: 4L0 910 517 A HW: 4L0 614 517 A Component: ESP ALLRAD MK25E1 0130 Revision: 00H21001 Coding: 0562305 Shop #: WSC 31414 790 00001 VCID: 2808089A6EF2B76BA7F-807C 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 118 Mileage: 188585 km Time Indication: 0 Date: 2022.07.17 Time: 12:45:30 Freeze Frame: Count: 0 Count: 4097 Count: 8206 Count: 40192 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb Part No SW: 4L1 910 732 H HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 387IX067523146 Coding: 0002001 Shop #: WSC 23922 401 96841 VCID: 2F3AE3864B1CE053665-807A Subsystem 1 - Part No: 4L0 910 609 Component: E0380 BedienteilH01 0060 Subsystem 2 - Serial number: 00000001691471 Subsystem 3 - Serial number: 0105.10.100000000100010687˙ Subsystem 4 - Serial number: 010687˙ 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 118 Mileage: 188585 km Time Indication: 0 Date: 2022.07.20 Time: 12:20:43 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4L0 910 111 A HW: 4L0 035 111 Component: CD-Changer H41 0100 Revision: 00000000 Serial number: AUZ5ZBF3044375 Shop #: WSC 00000 000 00000 VCID: 1E642E423CB679DBDD3-804A No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1229U7100556 Coding: 0000001 Shop #: WSC 31414 790 00001 VCID: 24101CAA12DA530B8B7-8070 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Cannot be reached ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4L0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4L0 920 930 B Component: KOMBIINSTR. M73 H17 0170 Revision: 00600000 Serial number: 5HA34MM96 Coding: 2801143 Shop #: WSC 80093 222 69422 VCID: 23121FB617D45433F2D-8076 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 36 Reset counter: 128 Mileage: 188585 km Time Indication: 0 Date: 2022.07.17 Time: 12:45:30 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 HW: 4L0 907 468 A Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0800D068288013 Coding: F7FFFE7F353E02 Shop #: WSC 22675 401 69414 VCID: 6C80348ABA8A5B4B037-8038 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 118 Mileage: 188585 km Time Indication: 0 Date: 2022.07.17 Time: 12:45:29 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4L0-910-553.lbl Part No SW: 4L0 910 553 B HW: 4L0 907 553 Component: LUFTFDR.-CDC H03 7550 Revision: --H03001 Serial number: 15.1528-0095.2 Coding: 0015520 Shop #: WSC 31414 790 00001 VCID: 290E0D9E75F88E63B81-807C 2 Faults Found: 01577 - Turn-Off due to Over-Temp 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 33 Reset counter: 166 Mileage: 185767 km Time Indication: 0 Date: 2022.05.09 Time: 07:33:47 Freeze Frame: Error Code: 68 00139 - Left Front Body Acceleration Sensor (G341) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 158 Mileage: 188585 km Time Indication: 0 Date: 2022.07.17 Time: 12:45:30 Freeze Frame: Error Code: 193 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4L0 959 760 Component: Sitzmemory FS H01 0100 Revision: 00000000 Serial number: 00000000896401 Coding: 0082946 Shop #: WSC 31414 790 00001 VCID: 619E55BE4D480623A01-8034 1 Fault Found: 01445 - Sensor for Driver Seat Fore/Aft (G227) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 128 Mileage: 185648 km Time Indication: 0 Date: 2022.05.04 Time: 15:06:58 ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 B HW: 4L0 907 566 A Component: J0769_SWA_MasterH07 0070 Revision: 00H07000 Serial number: 6PZ 009 014-00 Coding: 0010101 Shop #: WSC 23922 401 89084 VCID: 2D06F98E41109243549-8078 Subsystem 1 - Part No: 4L0 910 568 B Component: J0770_SWA_Slave_H06 0070 Subsystem 2 - Serial number: 6PZ 009 014-20 Subsystem 3 - Serial number: 3F21.03.0700H0600000010109˙ Subsystem 4 - Serial number: 010109˙ 2 Faults Found: 02850 - Control Module 2 for Lane Change Assistance (J770) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 185648 km Time Indication: 0 Date: 2022.05.04 Time: 15:07:01 16365 - Control Module - Electrical Error; CPU 2 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 89 Mileage: 181444 km Time Indication: 0 Date: 2022.01.04 Time: 09:25:44 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 D HW: 4L0 907 289 A Component: Komfortgeraet H05 0020 Revision: 0020 --- Serial number: 01019114180000 Coding: 7610609 Shop #: WSC 31414 790 00001 VCID: 313EE5FE5D28F6A3701-8064 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Subsystem 2 - Part No: 4F0 910 177 Component: Innenraumueberw.H01 0020 2 Faults Found: 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 128 Mileage: 172025 km Time Indication: 0 Date: 2019.11.18 Time: 19:54:18 02957 - Lamp in Trunk/Hatch Lid; Right 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 168 Mileage: 175781 km Time Indication: 0 Date: 2021.09.17 Time: 16:45:46 Freeze Frame: Bin. Bits: 111 000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 792 B Component: TSG BF H12 0130 Revision: 00-00000 Coding: 0019147 Shop #: WSC 31414 790 00001 VCID: 2F3AE3864B1CE053665-807A 2 Faults Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 185651 km Time Indication: 0 Date: 2022.05.04 Time: 15:07:13 02111 - Motor for Window Regulator 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 3 Fault Frequency: 70 Reset counter: 141 Mileage: 187408 km Time Indication: 0 Date: 2022.06.23 Time: 13:22:39 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000022 Shop #: WSC 31414 790 00001 VCID: 290E0D9E75F88E63B81-807C Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H06 0002 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH06 0002 1 Fault Found: 02234 - Right Headlight Power Output Stage (J668) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 40 Mileage: 187064 km Time Indication: 0 Date: 2022.06.12 Time: 10:15:47 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4L0 910 181 HW: 4L0 915 181 Component: J0644 BEM H12 0530 Revision: -------- Serial number: 00000000044063 Shop #: WSC 23922 401 89084 VCID: 64905CAA525A130B4B7-8030 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 2609071886 Coding: 344630393135313035442056413032363039303731383836 Shop #: WSC 31414 790 00001 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 68 Reset counter: 167 Mileage: 185717 km Time Indication: 0 Date: 2022.05.04 Time: 23:35:17
