- Joined
- Feb 16, 2011
- Messages
- 1,800
- Reaction score
- 333
- Points
- 83
- Location
- Bracknell
- Website
- www.sunnytree.co.uk
Hi all,
I've bought an RS3 last week and today during random scanning I found few faults.
Looks like one of the exhaust flaps is stuck and also the front passenger bass speaker has malfunction. The P062F code is my worry, could it be related to the speaker at all or it will be something else?
Here is full scan:
Here is full scan:
Code:
Saturday,20,August,2022,23:59:50:14646
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WUAZZZ8V5GA901325 License Plate: DT15JWY
Mileage: 89884km-55851mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 42 44 47 52 55 5F BB BC
VIN: WUAZZZ8V5GA901325 Mileage: 89884km-55851miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (------CZGB) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 HW: 07K 907 309 C
Component: 2.5l R5/4V TF X52 0005
Revision: NKX52--- CVN: B2E869DC
Coding: 12250032250601032600
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM25TFS0118V0907404 001006
ROD: EV_ECM25TFS0118V0907404.rod
VCID: 76E5DAC6C9FE0B3FE5-8022
VINID: 9E546AAAA2261574490010C214832F593A
2 Faults Found:
28221 - Control Module for Exhaust Flap 2
P14AC 00 [096] - Mechanical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 89862 km
Date: 2022.08.19
Time: 17:46:05
Engine RPM: 2018.50 /min
Normed load value: 6.3 %
Vehicle speed: 57 km/h
Coolant temperature: 92 ∞C
Intake air temperature: 41 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.020 V
Unlearning counter according OBD: 37
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
24449 - Internal Control Module EEPROM Error
P062F 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 89846 km
Date: 2022.08.19
Time: 11:49:37
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 50 ∞C
Voltage terminal 30: 12.200 V
Unlearning counter according OBD: 40
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Readiness: 0000 0001
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 011 D HW: 0BH 927 711 F
Component: GSG DQ500 H10 5201
Revision: 00H10V01 CVN: 85EA3938
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW37.rod
VCID: 295FC1BA48C014C7B8-807C
No fault code found.
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8V0 907 379 HW: 8V0 907 379
Component: ESC H42 0020
Revision: 00000000 Serial number: 61755000000010
Coding: 999CF08DBA9915AA40940866C396820644990F5DA80210C3416022
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
ROD: EV_Brake1UDSContiMK100IPB_061.rod
VCID: 010FB91A90303C87C0-8054
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000673759
Coding: 03100005000000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 336323D29A0C5E1702-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 0EC805B7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061516803280
Coding: 07041C46C24106FD03844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 091FA13AA80074C798-805C
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150612 042 0580
Serial number: 150619144507
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 24037939
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 18 04 2015 00001041
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY151460K29
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000032831936
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391517000477
Coding: 0030050011
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 43837312CAACEE9792-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 100615021
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R0W0NP5
Coding: 98CCC000008000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4B935B32E2FC26D76A-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 002 306 15
Component: SideSensor_Df 001 0887
Serial number: 357670000005A421351G
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 15
Component: SideSensor_Pf 001 0887
Serial number: 358670000000C421351E
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 402 306 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502BB1C52F33526C
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 402 306 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502BB1C52F353319
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 402 605 15
Component: FrontSensor_D 001 6149
Serial number: 3556502AB1B0CB3560AK
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 EF HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 23061504221399
Coding: 8418
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 020DB6169536279FD9-8056
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 971 N HW: 8V0 920 971 N
Component: KOMBI H02 6420
Coding: 278D080A3B8026000104E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 4899643EF38ACDCF47-801C
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1224
Revision: -------- Serial number: 0003636453
Coding: 030100043F0860005B000268B80B00000001010000000000000000000000
GVL: 01D43C0000000000400C10000000CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 75E7DDCAD4F80027EC-8020
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 03 06 2015 C0006080
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9041
Serial number: 3512796803
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7754
Serial number: HA1-00011.04.15
Coding: 0601
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 45876D0AC498D0A7BC-8010
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 090615BF805111
Coding: 00518A204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 377B17C28E74B2373E-8062
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAFN901CKG9
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 397F11FAB860A447C8-806C
1 Fault Found:
0590 - Front Left Bass Speaker
B105F 13 [143] - Open Circuit
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 101
Mileage: 89846 km
Date: 2022.08.19
Time: 11:49:26
Voltage terminal 30: 12.2 V
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 270515BEQ12468
Coding: 005182204001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428D7616D5B6E79F99-8016
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Revision: -------- Serial number: --------------
Coding: 01A600002B230200
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3F8B7FE2A6448A77F6-806A
Left LED Headlamp Power Output Stage 1:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Right LED Headlamp Power Output Stage 1:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Left Headlamp Power Output Stage:
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Right Headlamp Power Output Stage:
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V0 035 036 Q HW: 8V0 035 036 B
Component: MU-H-LND-EU H45 0404
Serial number: A300F0F7551121
Coding: 017303010000000021111102000A00102F00032701000100DE
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 40897C1EDBBAF58F8F-8014
Data carrier:
Subsystem 1 - Part No SW: V03 959 800 Q HW: -----------
Component: ECE 2015/2016 --- 0122
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY203DY7
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 K HW: 8V0 919 614 K
Component: ControlUnit_H H81 0816
Serial number: C1000026031500020190
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 080615BF702335
Coding: 004182204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 080615BF715453
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 04:40)--------------------------
