I have this problem for quite a while, it's a little annoying and I've found others online with the same problem with various ideas on the solution, so I've learnt to drive around it for the time being.
When under 2000rpm if I accelerate with light to moderate power it seems to lose power for a split second, almost as if the fuel has been cut off and you get a slight jerk. Sometimes it's just once and other times it can be a double jerk, all very fast though. Happens in Drive, Sport and Manual modes and pretty much all gears. If I accelerate very lightly or put my foot to the floor it doesn't happen. It also doesn't seem to happen when the car is cold. Over 2000rpm it never happens.
I'm wondering about the coil packs, but then wouldn't that also impact hard acceleration, cold engine, over 2000rpm etc? Has anyone experienced this and fixed it or have any ideas where to look next as I'm stumped.
- I've have a sporadic PCV code thrown up maybe twice in the last year but it clears and doesn't come back for months.
- No other codes are showing from the engine, transmission or any other module.
- I shoved in some Wynns Dry Fuel and I thought it worked but I think it was more a placebo effect.
- I use my local Esso which is very busy and I've also tried different fuel stations as well with no difference.
- Spark plugs were changed last year although I used Denso Iridium instead of NGK, could this be an issue? I've checked the gaps twice and they are good and they aren't fouled.
- Fuel trims are perfect.
- Oil is changed every 6 months
- DSG fluids changed, gearbox/diff/transfer case fluids all changed.
- Supercharger and aux belts all changed.
