Recall - issued 02/09/2022
Problem didn't come back after the "adjustments" so far but I doubt that they did anything apart from reflashing the software or something similar...
Sent from my XQ-CT54 using Tapatalk
Thank you, ill have to ask Audi to make "The Adjustments" and take it from there, not a big fan of Norwich Audi, when it went in the initial check and Oil change they damaged the offside Sill, it was hanging off, i had to take it to a body shop to have a new sill fitted ! It seemed that they lifted the car up on the sill !
I'm not a fan of any dealership... When I left my car for this gearbox issue and speaker rattle investigation, they damaged the gear knob trim, left airbox bolts loose and hoses detached. Then it turned out that the door card trim is damaged but extended warranty does not cover "rattles" and trims... Disgusted with dealership and VAG in general...
Trying to work this out from the post, if they update the car and it flags it's about to fail do they cover the work under a recall? Asking as my car is well out of warranty.
Assuming the work is significant if the update flags it?
890
11
