The boot on my 2010 Audi A3 won't lock. I was out earlier and noticed that when I locked the car the lights weren't coming on when I pressed the keyfob multiple times (which it normally does). Then when I came back to the car to drive home the dash warned that the boot was unlocked and I haven't been able to lock it since. Also the boot light isn't coming on.
I took off the trim and noticed that the rear washer is leaking a little when the tailgate is open which could be the cause. Can anyone help advise what I should do? Will it work again if it dries out? If not what do I need to replace? The boot open mechanism works fine when I press the boot open button on the keyfob but it just won't lock.
