B8.5 2012 2.0TDI quattro RHD
Ever since I've had this car I've had trouble with the brakes sticking. Firstly it was one of the rears but the calliper was actually seized so I changed it and all was well for a while, then occasionally the front brakes will drag slightly just for one journey and once they have cooled down again they seem to be ok for a while.
Most recently though the front left brake has been binding and once it gets warm its even worse, to the point that the disk is steaming hot after a few miles. So today I changed the calliper and went for a drive, the left front is now ok but the front right has started binding whereas before that one was fine.
when I dismantled the old calliper it did seem a bit stiff to push in with the rewind tool but I've taken the piston out and there aren't any score or rust marks marks on it and it now slides in and out freely. Is it worth changing the other front calliper and see what happens, I used a pump up bleeder to get the air out of the new calliper and I'm pretty confident I've done it correctly.
