From top to bottom:
Map 0
Map 1
Map 2
Map 3
Map 4
Map 5
Ran the first two with 91 and the rest with a mixture of ethanol.
From top to bottom:
Map 0
Map 1
Map 2
Map 3
Map 4
Map 5
Decent results for the JB4....
From top to bottom:
Map 0
Map 1
Map 2
Map 3
Map 4
Map 5
I've been running Map3 for a while now........I’d assume that we’re generally stuck running map 1 here in the uk then since we don’t have ethanol easily available.
There's a Firmware update coming that means they can see the Timing Adaption, only then can they start pushing things I was told.
That’s good to hear. Does it seem happy running that map on Momentum or V-Power I presume?
It’ll be interesting to see how much more they can get out of it being able to see the adaptations.
476hp not too shabby!
TX.
I just heard from George @ Burger, they completed the OBD data yesterday for the 'Sent' version cars, basically the USA versions, and are now adapting that firmware into a file for my uk JB4 for testing.That’s good to hear. Does it seem happy running that map on Momentum or V-Power I presume?
Do we have an idea when this will be actually for sale?
And then let the rest of us know.
Thats in the same league as tightening a bolt until it snaps and then back it off half a turnMore people that show an interest the more an incentive for them to release it.
So if my car blows up in the interim you know it’s not quite ready yet
Are you running the same P79 file that I'm running ?
I’ve literally just had this from George
Sny news on the jb4 for the uk cars yet bud? With the updated files we can use other maps apart from 0 on 99 octane?
It's funny...... I don't dislike it any more than i did, but i don't like it as much as my 8V......
Answer from me as well.
99 petrol shortage?Been using 3 maps on 99.
Had to revert to map 1 though until the 99 petrol shortage has been resolved then I can turn up the JB4.
99 petrol shortage?
Terminator slaughtered me for the same thingYup around here it’s always out of stock.
Golf8R forum reports similar from some owners.
Yeah and JB says their dyno reads a bit conservative as well. Stock should be up north of 400whp, although it could be a combo of a conservative dyno and 91 octane. None-the-less, it is a 100whp gain.476hp not too shabby!
TX.
No I guess not, shame eh!
Sent from my SM-F721U using Tapatalk
Going to be a bit pessimistic here, but with a quoted 400PS I’ll eat my hat if the car is actually seeing that at the wheels standard. With a conservative 10% drivetrain loss it would have to be 440 (ish) at the crank, and while these cars are usually better than quoted I imagine that is a little much.
Find me a car that weighs 3,600+ lb that can do 0-60mph in 3.3 seconds and the standing 1/4 mile in less than 12 seconds at almost 120mph (factory stock) with less than 400whp. It won't happen. The 5 cylinder is under-rated. If the car were rated at 400 crank hp and we assume a 10% drivetrain loss, that'd put it at 360whp. There is no way a 3,600+ lb car is going to trap 117mph in the 1/4 mile with 360whp. The physics just doesn't support it. I have a '17 Subaru WRX with 340whp and I only trap 105-106 on a good day and it's maybe a mid-high 12 second car.
I truly believe the car has around 440-450hp to the crank. There are many YouTube 8y dyno vids showing this car putting down 400-410whp without mods.
Here's one right here that shows 417 -
Same thing with the new M3c. BMW claims the car has 510hp, but the car does the 1/4 mile in 11.1 at 125mph. Again, assuming 10% drivetrain loss, there is no way an almost 4,000lb car is going to trap 125mph with 450whp. Most stock M3c's are dynoing 490-500whp. There's even a freak example of one putting down 538.
There’s a lot more to it than power though. How much more torque does the RS3 have versus your WRX, and over how much more of the rev range? Also, if your WRX revs higher than the RS3 that could mean it has less pulling power but similar WHP. The ‘area under the curve’ for torque will make a massive difference. As will closer ratios and a DSG box versus a manual.
I get your point, don’t get me wrong, it’s just not as simple as certain power means a certain acceleration so I would like to see WHP with gains for different maps on the same dyno on the same day for a tuning box to see the actual gains at the wheels more than the outright numbers.
