I have swapped the basic electric mirror motor with three wires, to an A5 memory motor with the green connector and six wires. This is for the right mirror (drivers).
The mirror adjusts and sets to memory position with the seats, so all good.... except the following problem:
Moving the adjustment button up, moves the mirror right; moving the mirror button down, moves the mirror left - basically the mirror movement is displaced by 90 degrees, all the way round.
I have done the same job (motor swap) on the left mirror with zero problems (all functions working as expected, inc memory set/movement). As such, I followed the same pin connections for the right hand side.
Anyone know why the adjustment is off by 90 degrees?
My hypotheses:
All help appreciated, so close to finalising this memory seat/mirror retrofit!
This is how I have wired both left and right mirror connectors, going into the door modules:
My hypotheses:
- Right mirror has a slightly different pin ordering for the connector to the door module.
- The car requires the new (right) mirror motor to be defined as a right/driver's mirror
- Car needs a scan and clearing any faults with VCDS (will be what i do first thing Sunday morning)
- Something else...
